Medabum Posted July 1, 2015 Report Share Posted July 1, 2015 Does anyone have service manual for this vehicle? I'm specifically looking for a diagram of the Power booster and or brake system for my 2015 journey. I've searched through old threads, googled, and looked at the mopar website, and can't seem to access what im looking for. I'm assuming the 2013-2015 information will be the same. I was told by the dealer that the journey Power booster doesn't have a spring. As you know I've been getting a springlike feeling every time my pedal is pressed. Just trying to locate what could be causing the problem before going back down to test drive with the technician.. daddyRT 1 Quote Link to comment Share on other sites More sharing options...
Milous Posted July 1, 2015 Report Share Posted July 1, 2015 Here is the booster description: The power brake booster is mounted to the engine side of the dash panel. The master cylinder is bolted to the front of the booster. A vacuum check valve is also mounted on the front of the booster. A vacuum line connects the check valve to engine source vacuum. The booster input rod extends through the dash panel and connects to the brake pedal. This vehicle uses a tandem diaphragm, single rate vacuum power brake booster with 203 and 229 mm (8 and 9 in.) diaphragms. Power brake boosters are internally tuned differently depending on whether the vehicle is equipped with ABS or without ABS. Attached file shows the main parts of the booster, 2nd file includes some diagnostics that you can try. 2015_JC_Brake_Booster.pdf 2015_Journey_Brake_Booster_diagnostics.pdf jkeaton, Medabum and daddyRT 3 Quote Link to comment Share on other sites More sharing options...
Medabum Posted July 11, 2015 Author Report Share Posted July 11, 2015 Milous, Within the booster itself have you seen the springs fail or catch? I appreciate you looking into the issue. Quote Link to comment Share on other sites More sharing options...
Medabum Posted July 11, 2015 Author Report Share Posted July 11, 2015 I have been looking at diagrams of tandem diaphragm boosters and some show springs internally and others do not. Quote Link to comment Share on other sites More sharing options...
daddyRT Posted September 29, 2015 Report Share Posted September 29, 2015 I'm experiencing the similar problem ever time I first hit my brake pedal it feels like a spring snap like feeling the it goes away . Till I hit the brake after long time of not hitting the brake pedal. dj cowboy 1 Quote Link to comment Share on other sites More sharing options...
