Buddy336 Posted August 10, 2015 Report Share Posted August 10, 2015 Install external amp and sound processer. Everything hook up and working, but radio has no output. I tapped off the door speakers and ran the high level input into sound processer. I've found that with my car if I start it with no speakers hook up the output is disabled untill I reconnect the speakers and leave the car turned off for a few hours. Then everything works. But with the external amp even when I leave it overnight the outputs are still disabled. Quote Link to comment Share on other sites More sharing options...
bramfrank Posted August 10, 2015 Report Share Posted August 10, 2015 So put a 4 ohm resistor across the speaker wires to simulate a load. dhh3 and Lobitz68 2 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted August 10, 2015 Report Share Posted August 10, 2015 So put a 4 ohm resistor across the speaker wires to simulate a load. This... You're vehicle doesn't see a load and isn't sending a signal to the speakers. dhh3 1 Quote Link to comment Share on other sites More sharing options...
