journeygal Posted August 11, 2015 Report Share Posted August 11, 2015 I filled the washer fluid (it was still 1/4 full) and push in the end of the wiper lever and the wipers operate but no fluid. Is there a quick fix for this or do I have find time to take it to the dealer? It worked before. I have 1500 hundred miles on the vehicle. Thanks! Quote Link to comment Share on other sites More sharing options...
bigtsr Posted August 11, 2015 Report Share Posted August 11, 2015 I filled the washer fluid (it was still 1/4 full) and push in the end of the wiper lever and the wipers operate but no fluid. Is there a quick fix for this or do I have find time to take it to the dealer? It worked before. I have 1500 hundred miles on the vehicle. Thanks! Open the hood and have someone actuate washer the hose may have become disconnected and you'll see washer squirting out , simple reconnect. Does the rear still work? Quote Link to comment Share on other sites More sharing options...
dhh3 Posted August 11, 2015 Report Share Posted August 11, 2015 Did you check the fuse? Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted August 11, 2015 Report Share Posted August 11, 2015 If you can hear the pump running then a hose came disconnected somewhere. I've had two little issues with mine, first the passenger side nozzle broke so it was spraying fluid all inside the engine bay. I super glued that to fix it. Later on, the stiff plastic hose broke on the driver side. Slipped a little rubber hose over the broken connections to get it running again. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted August 11, 2015 Report Share Posted August 11, 2015 Agree with other posts... if you hear the pump it is working. dhh3 1 Quote Link to comment Share on other sites More sharing options...
journeygal Posted August 11, 2015 Author Report Share Posted August 11, 2015 Thanks! I do hear the pump, so I'll have my husband help me check the hoses. I'll check the rear, also. I really appreciate the info. Will keep you updated. dhh3 1 Quote Link to comment Share on other sites More sharing options...
journeygal Posted August 11, 2015 Author Report Share Posted August 11, 2015 Yay! The hose was disconnected! Great idea to have one of us in the car, pressing on the button and the other under the hood, watching the fluid dripping down. Kind of a chintzy hose. It wouldn't stay together. No threads, catch or other fastener. So we resorted to tape for now. Wonder what made it fall off. You'd think with 1500 miles in town driving and no potholes, it wouldn't be an issue, but who knows. The hose does seem a bit short where it meets. Thanks again for the help and quick response! Trains123 and onecrazyfoo4u 2 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted August 12, 2015 Report Share Posted August 12, 2015 (edited) Roll by the dealer and have them replace the hose . . problem solved. Edited August 12, 2015 by bramfrank Quote Link to comment Share on other sites More sharing options...
bfurth Posted August 12, 2015 Report Share Posted August 12, 2015 And since you know exactly what the problem is, you can call them in advance and have them verify the part is in stock before you get there. Quote Link to comment Share on other sites More sharing options...
Trains123 Posted August 12, 2015 Report Share Posted August 12, 2015 My 2013 did the same thing Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted August 12, 2015 Report Share Posted August 12, 2015 I would not personally waste hours of my day to have the dealer replace $1 worth of washer hose. I just do it myself...but that's just me! 2late4u 1 Quote Link to comment Share on other sites More sharing options...
B4ZINGA Posted August 14, 2015 Report Share Posted August 14, 2015 Have the dealer replace it. Shouldn't take longer than half an hour. When my fluid sensor in the washer system disintegrated, I was in and out within half an hour. Just call ahead, tell them the hose on the bottle failed and needs to be replaced (and you've already confirmed this, no diagnosis needed), and set a time and day to come in. Any competent dealer will be ready for you. Common parts they normally have in stock. I'm also a little surprised that at 1500 miles the hose failed. I have over 15,500 on mine with no hose failure, in spite of 15,000 being on Michigan's sad excuse for paved roads and going through a nasty winter. But, then I'm also surprised that my fluid sensor failed before 13,000 miles (apparently the solvents in RainX dissolve the sensors that Dodge switched to sometime after my 07 Charger and 02 Special were made... both of which handle RainX just fine). Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 15, 2018 Report Share Posted January 15, 2018 (edited) well my front windshield squirts not working but the rear is thought it was froze up but i have the right fluid in there it it is only 25 degrees so i pop the hood and reach in and hit the squirter button and the hose is broke right at the end of the hood where it then makes a u turn going back towards the front and up to the squirt broke right at the u bend also they used a plastic tube hose cant believe they are that dam cheap. went and got a 5/32 rubber tube hose had to buy 6 ft as orileys only sells it in a package about $3.60 for the packet, cut about a foot of it and moisten the end and slid it over the plastic tube nice tight fit and then did the other end and then zip tied the hose to the old hose connectors clips as the new tube wouldn't fit thur the connectors....everything working great again... oh well thats life.. Edited January 15, 2018 by 2late4u jkeaton 1 Quote Link to comment Share on other sites More sharing options...
