timo Posted August 13, 2015 Report Share Posted August 13, 2015 I am trying to locate information on locating the fuse for the drivers side back window on a 2010 Dodge journey SXT 6Cyl. auto trans . The rear window went down fine, but won't go up either from the front conrol or the rear control. Any ideas? Quote Link to comment Share on other sites More sharing options...
bigtsr Posted August 13, 2015 Report Share Posted August 13, 2015 Welcome to the forum. Have you tried resetting the TIPM by disconnecting DJ battery for 10 - 15 minutes? Failing that I don't believe individual windows have their own fuse so I would suspect controller/motor for that door seeing that neither switch has control. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted August 13, 2015 Report Share Posted August 13, 2015 They may no longer do it this way, but in the past Dodges I have owned the driver's switch drives the others, so if there is something wrong with that one, others may not work. I would suggest taking the door panel(s) off and checking the switch. A dirty switch or a switch that isn't making good contact will act as described. Regardless, I agree that it is likely not a fuse. jkeaton and rolly 2 Quote Link to comment Share on other sites More sharing options...
