JacobGirty Posted August 18, 2015 Report Share Posted August 18, 2015 Haveing issues with what I call a death wabble with my steering. Have been having this issue since 50,000 miles have currently have 65,000 any one Haveing this issue? Quote Link to comment Share on other sites More sharing options...
Woah322 Posted August 18, 2015 Report Share Posted August 18, 2015 Get a balance or check for bent front rims Quote Link to comment Share on other sites More sharing options...
OhareFred Posted August 18, 2015 Report Share Posted August 18, 2015 Bad brake rotors, loose tire, out of balance tires, worn ball joints, bad tie rod. If you can be a little more specific we can too! When do you have the problem? All the time, when braking, highway speeds, etc.... jkeaton and dhh3 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 18, 2015 Report Share Posted August 18, 2015 (edited) Bad brake rotors, loose tire, out of balance tires, worn ball joints, bad tie rod. If you can be a little more specific we can too! When do you have the problem? All the time, when braking, highway speeds, etc.... ^^ this. The more info you provide, the better we can assist instead of asking you tons of questions to narrow it down. Probably a shimmy due to out of balance wheels or alignment issue. Or warped rotors if it does it while braking. Have you had the vehicle checked out by your dealer or a qualified mechanic? Edited August 18, 2015 by jkeaton dhh3 1 Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted August 18, 2015 Report Share Posted August 18, 2015 Death wobble ? Running 15,000 miles like that ....how bad . dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted August 18, 2015 Report Share Posted August 18, 2015 (edited) I concur. Warped rotor, or balance issue. My Crossroad wheel's use paste weights so I constantly check to see if any one has fallen off. Edited August 18, 2015 by dhh3 Quote Link to comment Share on other sites More sharing options...
bfurth Posted August 20, 2015 Report Share Posted August 20, 2015 I concur. Warped rotor, or balance issue. My Crossroad wheel's use paste weights so I constantly check to see if any one has fallen off. My Chrome-Clad rims have adhesive weights inside AND clip-on weights on the back side. When the time comes to put new tires on, if the shop in question puts balance weights on the face of the rim, I'm going to get angry... dhh3 1 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted August 20, 2015 Official Dodge Support Report Share Posted August 20, 2015 Just to echo what others have said, under what conditions are you experiencing this? What's your model year and engine type? Have you had it diagnosed? dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 20, 2015 Report Share Posted August 20, 2015 Will the OP be back.....stay tuned..... dhh3 1 Quote Link to comment Share on other sites More sharing options...
