Steering wheel shaking
  On 8/18/2015 at 2:52 AM, OhareFred said:
Bad brake rotors, loose tire, out of balance tires, worn ball joints, bad tie rod. If you can be a little more specific we can too! When do you have the problem? All the time, when braking, highway speeds, etc....
^^ this. The more info you provide, the better we can assist instead of asking you tons of questions to narrow it down.
Probably a shimmy due to out of balance wheels or alignment issue. Or warped rotors if it does it while braking. Have you had the vehicle checked out by your dealer or a qualified mechanic?
Edited by jkeaton
  On 8/18/2015 at 3:49 PM, dhh3 said:
I concur. Warped rotor, or balance issue. My Crossroad wheel's use paste weights so I constantly check to see if any one has fallen off.
My Chrome-Clad rims have adhesive weights inside AND clip-on weights on the back side. When the time comes to put new tires on, if the shop in question puts balance weights on the face of the rim, I'm going to get angry...
