Lobitz68 Posted October 26, 2015 Report Share Posted October 26, 2015 I sent an email to diodedynamics to see if they make a gizmo so that the inside LEDs can be a brake light too. They are not open on the weekends. I'm going to leave the signal amber Also, need recommendations for a brighter back up bulb. Type and bulb # would be great so I know what I'm looking for. Thank you. They won't have anything like that and won't offer suggestions without having a DJ to look at (I have spoken to them already). I'm still guessing that there just isn't anything connected to that 3rd pin inside the housing. It's not worth cracking it open to find out though, so I will just stick with my LED ring as the brake and turn. Still looks 100X better than the amber light. dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted October 26, 2015 Report Share Posted October 26, 2015 (edited) This is what I received so far: Hello,Thank you for contacting Diode Dynamics! Our switchback module would be something I would suggest you take a look at.http://www.diodedynamics.com/store/catalog/product/view/id/22660/s/s1-switchback-module-pair/category/1448/The only issue, if you want to call it that, is that you will only be able to choose either the brake or the turn signal for this function. This is just do to only having one high power input available to tap in with. Also you would need to swap the existing tail light bulb out to an LED option.Thank you,Phillipcontact@diodedynamics.com(314) 205-3033 x223 Ticket ID: MOQ-305-14094Helpful LinksTroubleshooter - Installation - Create an RMA - www.diodedynamics.com This is what I sent him back, which is basically what I sent them in the first place: I have no idea how any of this works! My Dodge Journey has 4 Red LED lights in the rear (Rings of Fire!). The turn signals are an amber incandescent bulb. The outside LED lights serve as brake and tail light. The inside LED lights are tail light only. I want the inside LED lights to be brake also, if this is even possible. The outside lights have 3 wires: brake, tail, and ground. The housings have 3 pins. The inside lights have 2 wires: tail and ground. However, the inside housings also have three pins. I plugged the inside light/housing to the outside harness, and the light still only worked as a tail light. The brake function didn’t work. Thus, the outer LED lights are dual intensity and the inside LEDs are single intensity. I was under the impression that a switchback is for two different colors for the same light. From: Diode Dynamics Sent: Monday, October 26, 2015 2:12 PM To: dhh_3@comcast.net Subject: [#MOQ-305-14094]: Inner LED tail lights as brake lights also Hello,Thank you for contacting Diode Dynamics! Our switchback module would be something I would suggest you take a look at.http://www.diodedynamics.com/store/catalog/product/view/id/22660/s/s1-switchback-module-pair/category/1448/The only issue, if you want to call it that, is that you will only be able to choose either the brake or the turn signal for this function. This is just do to only having one high power input available to tap in with. Also you would need to swap the existing tail light bulb out to an LED option.Thank you,Phillipcontact@diodedynamics.com(314) 205-3033 x223Ticket ID: MOQ-305-14094Helpful LinksTroubleshooter - Installation - Create an RMA - www.diodedynamics.com The part he recommended was a switchback! HUH? Edited October 26, 2015 by dhh3 jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted November 18, 2015 Report Share Posted November 18, 2015 I'll buy if and take pics and upload for all of us haha dhh3 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted November 23, 2015 Report Share Posted November 23, 2015 (edited) This should be as simple as adding a jumper wire from the turns to the markers... I love my LED rings as turns. Looks so much better. Edited August 3, 2016 by jkeaton Cody Chornobey Powley and dhh3 2 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted November 23, 2015 Report Share Posted November 23, 2015 If they work for turn signals, why won't they work as brakes? Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted November 24, 2015 Report Share Posted November 24, 2015 If they work for turn signals, why won't they work as brakes? I'm just using the outside lights as turns, not the ones on the hatch... Quote Link to comment Share on other sites More sharing options...
dhh3 Posted November 24, 2015 Report Share Posted November 24, 2015 OIC Quote Link to comment Share on other sites More sharing options...
