lstan Posted September 2, 2015 Report Share Posted September 2, 2015 my passenger doors are holding water. We checked drain holes, all seals on windows appear to be ok. Don't know how it is getting in. Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted September 2, 2015 Report Share Posted September 2, 2015 Your sure the clear sticker covering the drain holes in the doors are removed? That was a common problem on many DJ's; Dodge forgot to remove the drain hole stickers on all the doors and the hatch. Check the bottom of the doors to see... dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted September 2, 2015 Report Share Posted September 2, 2015 Was an issue on some of the Avengers trunk lids as well... jkeaton and dhh3 2 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted September 2, 2015 Report Share Posted September 2, 2015 I just checked mine. No clear stickers on my doors; the left side of my gate has a small round hole without a sticker and the right side has a big oval hole. It has a clear sticker with a small hole in it! jkeaton 1 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted September 2, 2015 Report Share Posted September 2, 2015 Stick a short piece of wire in each drain hole to make sure it's not plugged with assembly residues. dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
Journeyman425 Posted September 3, 2015 Report Share Posted September 3, 2015 Clear the drains in the doors - usually compressed air or a good strong shop vac in the drain holes with get the restriction out. dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
