tyeayo Posted September 8, 2015 Report Share Posted September 8, 2015 http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=181856110095&category=80741&pm=1&ds=0&t=1441736282219 Looking to do this and get a lockpick for it Is this all i will need? I have a 2014 dj sxt awd No navi No bluetooth No auto climate Yes sirius satellite Thanks dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted September 8, 2015 Report Share Posted September 8, 2015 I suppose it might if you speak Spanish. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted September 8, 2015 Report Share Posted September 8, 2015 I have no idea. English is my language of choice. dhh3 1 Quote Link to comment Share on other sites More sharing options...
silenze Posted September 9, 2015 Report Share Posted September 9, 2015 You would need the temperature sensors and light sensor. Otherwise your climate control wont display on the screen jkeaton and dhh3 2 Quote Link to comment Share on other sites More sharing options...
tyeayo Posted September 10, 2015 Author Report Share Posted September 10, 2015 I was judging based on the pictures it showed dhh3 1 Quote Link to comment Share on other sites More sharing options...
tyeayo Posted September 10, 2015 Author Report Share Posted September 10, 2015 You would need the temperature sensors and light sensor. Otherwise your climate control wont display on the screen What would the light sensor be for? I dont have auto lights switch nor do I have the sensor in the dash. So without the temp sensor, i would only be able to adjust it manually, where does the temp sensor plug in at? Do you happen to have the part number for that? dhh3 1 Quote Link to comment Share on other sites More sharing options...
tyeayo Posted September 14, 2015 Author Report Share Posted September 14, 2015 anyone? dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted September 14, 2015 Report Share Posted September 14, 2015 There is a thread on the forum that lists the 3 different sensors and their part numbers. You'll have to search because I don't remember the name of the thread. The thread was about adding auto headlights. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
tyeayo Posted September 21, 2015 Author Report Share Posted September 21, 2015 I would imagina the light sensor would be neccasary for the auto dim feature for the stereo, if I dont have that, will it keep it from working completely? Or just make the auto dim feature obsolete? dhh3 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted September 21, 2015 Report Share Posted September 21, 2015 I would imagina the light sensor would be neccasary for the auto dim feature for the stereo, if I dont have that, will it keep it from working completely? Or just make the auto dim feature obsolete? Auto dim?? I think it just dims when you turn the lights on. There are settings in the software for normal mode. It would dim to whatever you have it set at with the interior light dimmer by the headlight switch when the headlights are activated. dhh3 1 Quote Link to comment Share on other sites More sharing options...
silenze Posted September 21, 2015 Report Share Posted September 21, 2015 The light sensor is also used by the auto temperature controls. dhh3 1 Quote Link to comment Share on other sites More sharing options...
tyeayo Posted September 22, 2015 Author Report Share Posted September 22, 2015 Oh, I see So, minus the light sensor and temp sensor, will this work? I have come to terms with not having an exact display of the hvac in the journey, but other than not having that display, will i need anything else? dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted September 22, 2015 Report Share Posted September 22, 2015 I have auto HVAC and mine is a 3-row. Therefore I have rear HVAC and the only way that I know how to adjust it from the front is on the screen. You can manually adjust it from the second row, but I have it locked on the screen so no one can change the way that I have it set. I have never been able to get the screen auto dim to work. With headlights off, I have it set to 10. With headlights on, I have it set to 8. I dim the screen to 8 by rotating the dimmer switch down one click. If you do not have the sensor, I have no idea if any of these functions will work for you. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
silenze Posted September 23, 2015 Report Share Posted September 23, 2015 You wont be able to see what the temperature is set at. You can manually change the temp by hitting the buttons. But nothing on the screen will work. And it wont display any changes. Dont say we didn't warn you dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted September 28, 2015 Report Share Posted September 28, 2015 If you haven't found the posts in question, this is what I recall:There are three variants of the dash sensor. Two of them include an ambient light sensor which is used to control the automatic headlights - you would also need to replace the light switch assembly and have the sales code programmed into your vehicle if you wanted to enable this. Two of the sensors have the temperature sensor for the automatic air conditioning. So there is one with auto lights only, another which is auto air conditioning only and the third has both - if you have a base vehicle you have no sensor at all.There is the possibility that you may also need to add a wire between the sensor and the radio, depending on the wiring harness your vehicle is equipped with. Unless you have the right sensor and the proper connections, it would seem that you will not be able to enable automatic air conditioning nor apparently to control the climate control system heat from the touchscreen. redtomatoman and dhh3 2 Quote Link to comment Share on other sites More sharing options...
tyeayo Posted September 29, 2015 Author Report Share Posted September 29, 2015 Ok, so its what I figured than, this WILL work, but I wont have the ability to viualize the temp setting, it will move, but than revert back to the middle of the setting. I will be able to control the temp, but only through the buttons on the dash, NOT through the touch screen though. I am really wanting navigation, and it seems the only route will be with either:a standalone garmin or tomtom unit an aftermarket double din unit (requires buying the 350$ bezel and havac controls) or getting the 8.4 uconnect with navi and losing the ability to manipulate the temp settings through the touch screen I think I'm just gonna go the OEM way and lose out on the wiz bang ooh ahhh ability of touching the screen to manipulate the temp. It will be cleanest looking and it will actually be easier than replacing with a double din and having to buy the cheap looking aftermarket radio bezel. Quote Link to comment Share on other sites More sharing options...
bramfrank Posted September 30, 2015 Report Share Posted September 30, 2015 I used a Garmin 3490 in my last Journey (it was an SE Plus) and it worked well for me because it provided Bluetooth as well as nav functions and I mounted it above the mirror, so it was not visible to the casual observer and it supported voice command (something you will not have with your upgrade, by the way, since it needs the buttons on the steering wheel to work). When I got my Crossroad I decided to go with the OEM solution and I have been pleased. Even though you've decided not to go that route (I'm including it for anyone who might read this topic while researching an nav update for their vehicle), one thing to keep in mind is that an aftermarket radio may well compromise access to touchscreen accessed features like heated seats, the electrical outlet and control of daytime running lamps if you have them. If your radio comes from a post-2012 vehicle you will need to get a PIN - we have a member here who has been helpful in generating them - you can PM me for details if you wish because I'm not certain he wants his name 'out there'. Quote Link to comment Share on other sites More sharing options...
tyeayo Posted October 27, 2015 Author Report Share Posted October 27, 2015 I used a Garmin 3490 in my last Journey (it was an SE Plus) and it worked well for me because it provided Bluetooth as well as nav functions and I mounted it above the mirror, so it was not visible to the casual observer and it supported voice command (something you will not have with your upgrade, by the way, since it needs the buttons on the steering wheel to work). When I got my Crossroad I decided to go with the OEM solution and I have been pleased. Even though you've decided not to go that route (I'm including it for anyone who might read this topic while researching an nav update for their vehicle), one thing to keep in mind is that an aftermarket radio may well compromise access to touchscreen accessed features like heated seats, the electrical outlet and control of daytime running lamps if you have them. If your radio comes from a post-2012 vehicle you will need to get a PIN - we have a member here who has been helpful in generating them - you can PM me for details if you wish because I'm not certain he wants his name 'out there'. Yeah, aftermarket is out completely, although clever, I am not a fan of the replacement bezel necassary for an aftermarket application. Quote Link to comment Share on other sites More sharing options...
