xcaliber81 Posted October 12, 2015 Report Share Posted October 12, 2015 I forgot to ask that when I bought it lol. I notice when I lock the car I have a flashing red light but if I lock the car with the window open and open it from the inside handle nothing happens. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted October 12, 2015 Report Share Posted October 12, 2015 (edited) My window sticker doesn't mention alarm, and I do not have any blinking light. The blinking red light should indicate an alarm. Possibly the alarm doesn't set when you leave the window open. BTW, where is the light? Edited October 12, 2015 by dhh3 Quote Link to comment Share on other sites More sharing options...
xcaliber81 Posted October 12, 2015 Author Report Share Posted October 12, 2015 (edited) On the tachometer on the lower right side once I lock the car it flashes. Edited October 12, 2015 by xcaliber81 dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted October 12, 2015 Report Share Posted October 12, 2015 (edited) Does the light flash when you lock the doors with the button in the door handle? That light comes on when I initially start the car, but it does not blink when the engine is off and the doors are locked. No alarm for me, as per window sticker. Edited October 12, 2015 by dhh3 Quote Link to comment Share on other sites More sharing options...
xcaliber81 Posted October 12, 2015 Author Report Share Posted October 12, 2015 It does with either it seems. dhh3 1 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted October 13, 2015 Report Share Posted October 13, 2015 Put the drivers window down , lock the door with the fob then reach thru the window and open the door using the inside handle. Make sure you don't have the fob on you as the DJ will recognize you. dhh3 1 Quote Link to comment Share on other sites More sharing options...
xcaliber81 Posted October 13, 2015 Author Report Share Posted October 13, 2015 Yea I had the fob on me lol. I did as you said big but with the fob I'll try again Thursday. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted October 13, 2015 Report Share Posted October 13, 2015 Yea I had the fob on me lol. I did as you said big but with the fob I'll try again Thursday. Thursday? Ha! Don't have the 10 seconds available to try it now? dhh3, rolly and jkeaton 3 Quote Link to comment Share on other sites More sharing options...
xcaliber81 Posted October 13, 2015 Author Report Share Posted October 13, 2015 No I'm in smithers bc lol I'm a truck driver haha rolly and dhh3 2 Quote Link to comment Share on other sites More sharing options...
Kech Posted October 15, 2015 Report Share Posted October 15, 2015 I just gave it a try and the red light does continuously blink with the engine off... dhh3 1 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted October 15, 2015 Report Share Posted October 15, 2015 My Crossroad claims to have an alarm. I have no clue whether it works or not and I don't care because even if it does go off no one pays attention to these things anyway. BrianS 1 Quote Link to comment Share on other sites More sharing options...
xcaliber81 Posted October 17, 2015 Author Report Share Posted October 17, 2015 So today I noticed as I locked I used the button on the handle the light flashes fast for about 30 seconds and after that it goes to a normal type of flash. Today I'll play with it see if I can make it go off. Could it be a type of immobilizer and not a honk type alarm? dhh3 1 Quote Link to comment Share on other sites More sharing options...
webslave Posted October 18, 2015 Report Share Posted October 18, 2015 From the User's Guide: THEFT ALARM To Arm: • Press the Keyless Enter-N-Go™ Start/Stop button until the Electronic Vehicle Informa- tion Center (EVIC) indicates that the vehicle ignition is “OFF”. Press the power door lock switch while the door is open, press the Key Fob LOCK button, or with one of the Key Fobs located outside the vehicle and within 5 ft (1.5 m) of the driver's and passenger front door handles, press the Keyless Enter-N-Go™ LOCK button located on the door handle. NOTE: After pressing the Keyless Enter-N-Go™ LOCK button, you must wait two seconds before you can lock or unlock the vehicle via the door handle. To Disarm: • Press the Key Fob UNLOCK button or with one of the Key Fobs located outside the vehicle 12 and within 5 ft (1.5 m) of the driver's and passenger front door handles, grab the Keyless Enter-N-Go™ door handle and enter the vehicle, then press the Keyless Enter-N-Go™ Start/Stop button (requires at least one valid Key Fob in the vehicle). The alarm system will arm if you use the keypad on the armrest or the key fob/fobic. It will not arm if you have a key and use the door lock cylinder or if you manually push each door's lock plunger. IIRC, besides the lights flashing and horn blowing, that some models (high end) of the FMC (feels funny using that instead of MOPAR) line also included shifter locks and fuel pump interlocks; effectively disabling the car from being hotwired. I don't know which specific models included those features or, even if it is still valid, but, vaguely remember reading about it somewhere... dhh3 1 Quote Link to comment Share on other sites More sharing options...
xcaliber81 Posted October 18, 2015 Author Report Share Posted October 18, 2015 So I have to press all 3 lock buttons? Seems a little much lol. dhh3 1 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted October 18, 2015 Report Share Posted October 18, 2015 (edited) So I have to press all 3 lock buttons? Seems a little much lol. No. You can do any of the three; Lock the door with the FOB, with the button on the handle, or simply by locking the door with the lock switch on the armrest as you exit the vehicle. It is essentially a passive system. And the vehicle has an immobiliser, whether it has an alarm or not. That is a requirement of ALL vehicles manufactured for sale in North America after some specific date long past . . . . so it is going to he a horn honking and light flashing alarm - in fact it would need to be, by definition, since an 'immobiliser' is not an 'alarm'. An alarm is an alerting system. Edited October 18, 2015 by bramfrank Quote Link to comment Share on other sites More sharing options...
