cskmom Posted October 18, 2015 Report Share Posted October 18, 2015 Hi guys...... I can't seem to find the previous thread where advice was given as to why not to purchase Sylvania silverster, and instead go for a Mopar HI R something? Reason that was given is that the Sylvania version is no better than the factory lights on the 2014 CVP??? I want the cheapest option possible for brighter lights to be used for Winter driving. I am in Canada Thanks dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted October 18, 2015 Report Share Posted October 18, 2015 I believe that Silverstars would be whiter (maybe brighter) than stock, but I just read a thread where we shouldn't use HIRs (maybe HIDs). It's all Greek to me. Eventually, I'm installing Silverstars as long as I can get the store to do it for me! Doesn't appear to be a lot of room to do this. With all my back issues I can't be bent over that long! jkeaton 1 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted October 18, 2015 Report Share Posted October 18, 2015 (edited) It is 'don't install HIDs' unless you use a full projector, which is a lot of work and means modifying your reflectors. HIRs work fine, but you need to trim one tab on each bulb to make it fit.Bulbs like Silverstars are simply white/blue tinted bulbs, unless you go for high wattage bulbs, which is a very slippery slope.Daniel Stern has a bunch of useful information on the topic of bulb technology: www.danielsternlighting.com Edited October 18, 2015 by bramfrank jkeaton 1 Quote Link to comment Share on other sites More sharing options...
xcaliber81 Posted October 18, 2015 Report Share Posted October 18, 2015 (edited) I'm eventually going to install piaa replacement bulbs as i find there the best halogen I've came across. Edited October 18, 2015 by xcaliber81 dhh3 1 Quote Link to comment Share on other sites More sharing options...
cskmom Posted October 18, 2015 Author Report Share Posted October 18, 2015 I'm eventually going to install piaa replacement bulbs as i find there the best halogen I've came across. Does this mean you will require a kit to make it fit? http://www.piaa.com/store/c/21-Automotive-Bulbs.aspx dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted October 19, 2015 Report Share Posted October 19, 2015 Does this mean you will require a kit to make it fit? http://www.piaa.com/store/c/21-Automotive-Bulbs.aspx Not if the bulb size and type is the same. dhh3 1 Quote Link to comment Share on other sites More sharing options...
xcaliber81 Posted October 19, 2015 Report Share Posted October 19, 2015 (edited) No you get the replacement size bulb, in my caliber they were H3 Edited October 19, 2015 by xcaliber81 dhh3 1 Quote Link to comment Share on other sites More sharing options...
cskmom Posted October 19, 2015 Author Report Share Posted October 19, 2015 A quick glance of the site doesn't produce bulbs for the dodge journey 2014 low and hi beams dhh3 1 Quote Link to comment Share on other sites More sharing options...
xcaliber81 Posted October 19, 2015 Report Share Posted October 19, 2015 (edited) If the 14 and 15 use the same bulb type it's listed here as 9006 and 9005 and should be available at any parts stores locally and the piaa bulbs have a 1 year warranty if they burn out. Edited October 19, 2015 by xcaliber81 dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted October 19, 2015 Report Share Posted October 19, 2015 A quick glance of the site doesn't produce bulbs for the dodge journey 2014 low and hi beams Do you know what size you're looking for? Maybe more than a quick glance is in order. dhh3 1 Quote Link to comment Share on other sites More sharing options...
