B4ZINGA Posted October 26, 2015 Report Share Posted October 26, 2015 The Journey's rear calipers need the piston to turn in order to compress it? That's a first. I've never seen an American car need that.... only Volvos. Was it designed in Sweden or something? dhh3 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted October 26, 2015 Report Share Posted October 26, 2015 The Journey's rear calipers need the piston to turn in order to compress it? That's a first. I've never seen an American car need that.... only Volvos. Was it designed in Sweden or something? All of them I have done have been that way, including a couple Japanese cars too... Quote Link to comment Share on other sites More sharing options...
bfurth Posted October 26, 2015 Report Share Posted October 26, 2015 The 4th generation Chrysler vans had it the same way (separate parking brake in rear wheels, floating caliper for hydraulic brake, no spinning required to compress the piston). Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted October 27, 2015 Report Share Posted October 27, 2015 Wish ours were that way. Even with the tool, I find it quite annoying and it makes the brake job take that much longer. Oh well... Quote Link to comment Share on other sites More sharing options...
jkeaton Posted October 27, 2015 Report Share Posted October 27, 2015 The first car I ever owned with rear disks, 1991 Ford Taurus, had the pistons than needed to be turned in. I had never been exposed to that before and ruined a caliper trying to figure out how to compress it. I believe it has something to do with the parking brakes. I'm thinking some, like Chryslers with the drum brake parking brake system inside the rotor, don't need to be turned to compress. I don't know, either way, they have been around for a long time. All the vehicles I own now with 4 wheel disks, Ford, Dodge, Hyundai, Mitsubishi and Honda all need to have the piston turned to compress it. Quote Link to comment Share on other sites More sharing options...
bfurth Posted October 27, 2015 Report Share Posted October 27, 2015 It's simple to tell the difference. If there is a spring retained arm on the back of the caliper, you will need to turn it and compress it simultaneously to seat the piston for new pad installation. If there is no arm, there is no parking brake mechanism inside the caliper, and the piston can be compressed with nothing more than a c-clamp (or other appropriate brake tool if you prefer). Quote Link to comment Share on other sites More sharing options...
Neto Posted October 28, 2015 Report Share Posted October 28, 2015 (edited) Rear disk brakes have always needed to be turned to seat. You can buy a kit from Harbor Freight for about $30 that has adapters for all makes and models. The 2009 Journey is my first ever car with rear disk brakes. I tried to press the cylinder back in with a large C-clamp, but I saw that it was not going back in, so fortunately I stopped before I ruined anything. I was able to rent an air tool from a local shop for a reasonable fee, but I will buy my own before I tackle it again. But that time I had it all apart already, and couldn't wait for a tool to arrive. But anyway, I figured all of the regular grease monkeys on here already knew it, but this guy is someone who, from what I understood from the original post, is someone who is wanting to learn, and I figured it didn't hurt to mention it, because no one else had. Edited October 28, 2015 by Neto jkeaton and OhareFred 2 Quote Link to comment Share on other sites More sharing options...
