remove the front chrome grill
Billy Billy
I want to remove the front chrome grill on my DJ , My Question is. after I remove the tabs, Do I just pull the grill straight toward me or up wards and then out toward me, I try this last weekend and it look like the bottom of the grill is attached to the bumper still. So do I pull on the honey comb grill toward or leave it alone?
  On 10/24/2015 at 2:31 PM, dhh3 said:
Curious as to why you want to remove your grill after you installed those good looking SS Wire Mash inserts.
I need to install the bottom grill with the allen bots it came with. I try to use 3m tape but it didnt hold up too well and I cant figure out how to get to the bottom grill from under the bottom of the car. I did search but I only find topic on it. I understand how to remove it from the top part but I cant get it to come out from the bottom. I guess I should had ask, do I pull out toward the street or pull up and how much force will it take or is there something on the bottom I need to undo before I try to pull the grill out.
I want to pull the top grill out so i can install the lower grill cause it looks like if i get the top grill out completely then I can stick my arm in behind the front bumper and bolt in the bottom grill
Edited by Billy Billy
Well Never mind, I just pulled it off and took a chance, I am thankful to say it didnt break lol... It is now installed in the lower grill of the bumper this time with the washers and spaces to the nut , haha not me !
I went ahead and took some pictures of it
open with 3 tabs in the center that pop out and 2 tabs on the sides that pop out//
2 tabs on the pass side
again 2 tabs but on the driver side
Now I think what can I do with that grill now that I know how to pull that bad boy out. Oh man my mind is in over gear ! Maybe I will spray paint the black inside part of the chrome grill that is black a chrome color or buy some paint that matches my paint and paint it then clear coat it.. I think the black plastic look inside the chrome is cheap. It needs to either be painted or chromed. I think black paint with clear coat would look nice.
I like the black cross bars... I would paint the chrome to match the paint.
