dewitt Posted November 9, 2015 Report Share Posted November 9, 2015 The last three days my journey will not start without getting a boost. No noises, lights and radio still work. The break is hard to push when trying to start it. The check engine light comes on after I get a boost. Battery checks out to be good. Any idea what is going on? dhh3 1 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted November 9, 2015 Report Share Posted November 9, 2015 Your battery may still be bad . . . . what diagnostic code is shown? As to the 'hard' brake pedal, that is absolutely normal once the vacuum has bled off. Quote Link to comment Share on other sites More sharing options...
dewitt Posted November 9, 2015 Author Report Share Posted November 9, 2015 not sure what you mean by diagnostic code? dhh3 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted November 9, 2015 Report Share Posted November 9, 2015 If the check engine light comes on then there should be a diagnostic code that tells you what is going on. Have the code read and you will likely have your answer. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dewitt Posted November 9, 2015 Author Report Share Posted November 9, 2015 something throttle position something!!! i think Quote Link to comment Share on other sites More sharing options...
jkeaton Posted November 9, 2015 Report Share Posted November 9, 2015 Post the exact code. Or search the Internet for a description of the code. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted November 9, 2015 Report Share Posted November 9, 2015 something throttle position something!!! i think Post the exact code. Or search the Internet for a description of the code. Agreed. You will get a lot better advice if we can see the code. It's probably not a fix that will be hard to figure out if there is a code popping up. rolly, jkeaton, dhh3 and 1 other 4 Quote Link to comment Share on other sites More sharing options...
