Won't shift out of park when ESP light is on
Renee2010
  • 3 years later...
  • 1 year later...
I’m also now having this problem. I have tried replacing the brake light switch which tells the car your foot is on the brake to allow you to take it out of park but that wasn’t it. Also tried testing the fuse for abs esp BAs and it’s hot. Anything else anyone can think of that could be an easy fix?
as you see we have posters asking for help but then  never come back to report what they found to be the problem,so when you figured it out please report back what you found out that fixed it,there is a neutral switch in the middle console at the bottom towards the front that should enable you to put the car in neutral,,, the owners manual has the info on how to  do it ,if you have no owners manual one can be down loaded off the internet just google it....good  luck
