power port
Check the fuse FIRST.
How about the socket in the console or the one behind the console?
It's actually not hard to get to the back of the socket . . . . you remove the two chrome-like trim pieces on either side of the pushbuttons (with a PROPER trim tool), then the 2 screws holding the pushbuttons in place and remove the lower stack - you may also have to remove the radio (I don't remember if it is accessible with the radio in place, but it's only a matter of 4 more screws) the socket is behind and to the right.
Dis-assembly instructions are in the opening pages of the backup camera instruction manual:
http://starparts.chrysler.com/info/default/K6861161.pdf
Edited by bramfrank
