Blackout Posted December 17, 2015 Report Share Posted December 17, 2015 Hey Everyone, So I installed LowBeam Sylvania SilverStar Ultra & HighBeam Silverstar Ultra all I can say is wow what a difference in lighting! I want to upgrade my fogs to something similiar like the silverstar ultra Any suggestions? 2013 Journey R/T dhh3 1 Quote Link to comment Share on other sites More sharing options...
Blackout Posted December 17, 2015 Author Report Share Posted December 17, 2015 Also question about LED bulbs they have to be canbus compatible correct? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 17, 2015 Report Share Posted December 17, 2015 HID! Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted December 17, 2015 Report Share Posted December 17, 2015 HID! NO!!! Not in the fogs please.... QuarterSwede, Cody Chornobey Powley and dhh3 3 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 17, 2015 Report Share Posted December 17, 2015 NO!!! Not in the fogs please.... You would be amazed at the light output. and the number of times other drivers flash their high beams..... Lobitz68, dhh3 and dj cowboy 3 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 17, 2015 Report Share Posted December 17, 2015 Old people like old tech. dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 19, 2015 Report Share Posted December 19, 2015 Just got these today. Will add pics after installing. larryl, dj cowboy, SeanTacular and 1 other 4 Quote Link to comment Share on other sites More sharing options...
SeanTacular Posted December 20, 2015 Report Share Posted December 20, 2015 How many Watts are those bad boys JK? Quote Link to comment Share on other sites More sharing options...
OhareFred Posted December 20, 2015 Report Share Posted December 20, 2015 How many lumins is the question...led may only be 5 watts... jkeaton and QuarterSwede 2 Quote Link to comment Share on other sites More sharing options...
SeanTacular Posted December 21, 2015 Report Share Posted December 21, 2015 (edited) Ya possibly 5w a diode. I want to know the wattage the lights pull. Thanks. Edited December 21, 2015 by SeanTacular Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 21, 2015 Report Share Posted December 21, 2015 35 SeanTacular 1 Quote Link to comment Share on other sites More sharing options...
Blackout Posted December 24, 2015 Author Report Share Posted December 24, 2015 Boys,Im starting to see more people with LED lowbeam & highbeams and I want something brighter then the silverstar ultras Everyone says you need canbus compatible bla bla bla I dont know much about any of this Can someone guide me the right parts lowbeam highbeam and fog lights LEDS and what brand to get and from there & ill definently buy them My only concern is the lighting house for the lowbeam putting LEDS will it melt anything? People say HIDS you have to be careful because it will melt the housing Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 24, 2015 Report Share Posted December 24, 2015 I just got these for the high beams. Will report once installed. SeanTacular and 11journeybama 2 Quote Link to comment Share on other sites More sharing options...
Blackout Posted December 25, 2015 Author Report Share Posted December 25, 2015 Let me know when you get them installed how well they are Im really interested Where did you buy them at as well? I want good ones! Merry Christmas Everyone Quote Link to comment Share on other sites More sharing options...
vozaday Posted December 25, 2015 Report Share Posted December 25, 2015 Hope they work out better for you than LEDs have for me. I find the beam control makes a high and low hotspot rather than a focused centre hot spot that will give you distance. So in another words a lot of light on the ground but none where it counts. If they turn out well for you then maybe I'll consider it. Quote Link to comment Share on other sites More sharing options...
Blackout Posted December 29, 2015 Author Report Share Posted December 29, 2015 How did it work out for you those LED lights? Any pictures? Where did you buy them from and did they fit properly? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted January 1, 2016 Report Share Posted January 1, 2016 (edited) Fog lights need modification. I know it's been said that tabs need to be trimmed so I thought I'd put some pics up. All the aftermarket bulbs I have bought for the fogs have needed to have the tabs completely removed. There are three. Two on one side and one on the other. On the aftermarket bulbs I have purchased, the two tabs on one side are set farther apart than the stock bulbs and the one on the other side is in the wrong position. So I shaved all the tabs off. Even then, it takes some wiggling and force to get them in. Here's some pice showing the stock bulb and the aftermarket after I shaved off the tabs. Edited January 1, 2016 by jkeaton SeanTacular 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted January 1, 2016 Report Share Posted January 1, 2016 When I got mine I had to change the rubber seal then it snapped right in otherwise it wouldn't fit but I had the correct tabs jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted January 1, 2016 Report Share Posted January 1, 2016 Interesting. I've had 3 sets now that the tabs are incorrect even though the bulb number is the same. Quote Link to comment Share on other sites More sharing options...
larryl Posted January 1, 2016 Report Share Posted January 1, 2016 I got then from Ebay also and the seller specified that the tabs were correct which I didnt get but now I do Quote Link to comment Share on other sites More sharing options...
tyeayo Posted January 5, 2016 Report Share Posted January 5, 2016 Interesting. I've had 3 sets now that the tabs are incorrect even though the bulb number is the same. Pretty sure they manufactured the mold wrong they didn't remold it after they fitted it to the 1st mold of the oem base, giving us a "mirror" opposite Quote Link to comment Share on other sites More sharing options...
jkeaton Posted January 5, 2016 Report Share Posted January 5, 2016 Pretty sure they manufactured the mold wrong they didn't remold it after they fitted it to the 1st mold of the oem base, giving us a "mirror" opposite Could be. Three different manufacturers got their molds wrong then. Quote Link to comment Share on other sites More sharing options...
Blackout Posted January 6, 2016 Author Report Share Posted January 6, 2016 Hey any possible way we can see some pictures with the LEDS & fogs on how it looks Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted January 8, 2016 Report Share Posted January 8, 2016 I ditched these bulbs and fogs, just installed my mini h1/6.0 projectors. They are amazing!!! Quote Link to comment Share on other sites More sharing options...
vozaday Posted January 8, 2016 Report Share Posted January 8, 2016 I ditched these bulbs and fogs, just installed my mini h1/6.0 projectors. They are amazing!!! Haha I could imagine, did you end up wiring the solenoid? It would be awesome having a quad retro and projected fogs like that. Quote Link to comment Share on other sites More sharing options...
