QAGuy Posted December 19, 2015 Report Share Posted December 19, 2015 My 09 Journey is having transmission issues. The shifter is stuck in Park but the indicator shows it is in Reverse. The back up lights are on and it acts as if it is in gear. Gear shift will not budge and the vehicle will not start. I have tried the "punk lever" fix to no avail. Is there a bypass manual way to shift the transmission to Park? Any ideas on how to fix this?? dhh3 1 Quote Link to comment Share on other sites More sharing options...
QAGuy Posted December 19, 2015 Author Report Share Posted December 19, 2015 Sorry that should have said pink lever, not punk! dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted December 20, 2015 Report Share Posted December 20, 2015 No knowing what the pink lever fix is, it won't start because it thinks it is in gear. Can you get under it and see if anything is wedged in the linkages? Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 20, 2015 Report Share Posted December 20, 2015 No knowing what the pink lever fix is, it won't start because it thinks it is in gear. Can you get under it and see if anything is wedged in the linkages? https://www.youtube.com/watchHad to gogggle pink thinging fix lol Quote Link to comment Share on other sites More sharing options...
