Ryan Trezise Posted December 30, 2015 Report Share Posted December 30, 2015 Hi. I have a 2012 Journey. I have to replace my touchscreen (part number 05064993AH) Can someone please tell me that the difference is with the letters at the end. I have been told that the AH replaced the AG and the AI replaced the AH etc.....Does this mean that any will work in my car? Also is there and difference with the 2013/14 model? I have the opportunity to purchase one fairly cheap, will this work in my car? Thank you in advance for any help/advice anyone can give. dhh3 1 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted December 30, 2015 Report Share Posted December 30, 2015 (edited) correct - any display and digitiser from a 2011 and later Journey will work, though it is generally accepted that it is preferable to use the same or later versions of a part (higher suffix code) . . . are you certain, however that it is the display and not a loose plug or the radio that is the problem? Edited July 29, 2016 by jkeaton Quote Link to comment Share on other sites More sharing options...
dhh3 Posted December 30, 2015 Report Share Posted December 30, 2015 If there is a change in the letters, it is a minor upgrade, and will work. If there is a change in the last number, it is a major upgrade, and may not work. Quote Link to comment Share on other sites More sharing options...
Ryan Trezise Posted January 1, 2016 Author Report Share Posted January 1, 2016 thanks for you help guys! Just so I got this right the later model ones like say a 2014 model touchscreen will work on my 2012 Journey? Is it just the mounting location slightly different? I could use my current mounting plate? Quote Link to comment Share on other sites More sharing options...
