MsWill2u Posted January 29, 2016 Report Share Posted January 29, 2016 2009 dodge journey. Brake and reverse lights don't work. Bulbs are fine. Is there a fuse for this? Where is it located? Please help! Thanks. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted January 29, 2016 Report Share Posted January 29, 2016 This is from my 2014 Manual: There are no individual fuses for the back up or brake lamps. However, there are 2 40a green fuses, labeled "Exterior Lights 1" and "Exterior Lights 2". These are both located in the fuse block under the hood. Hope this helps. Quote Link to comment Share on other sites More sharing options...
MsWill2u Posted January 29, 2016 Author Report Share Posted January 29, 2016 Thank you :-) dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted January 29, 2016 Report Share Posted January 29, 2016 Let me know if you have issues. I do know that the 2009 and 2010 were basically the same, but there were major changes in 2011 to present. Quote Link to comment Share on other sites More sharing options...
MsWill2u Posted January 29, 2016 Author Report Share Posted January 29, 2016 I will let you know how it goes. dhh3 1 Quote Link to comment Share on other sites More sharing options...
MsWill2u Posted January 30, 2016 Author Report Share Posted January 30, 2016 Thanks again dhh3. Fuses changed. Fuse ox was labeled. I used a fuse tester and changed all that needed changing. LOL. Did the trick. dhh3, jkeaton and 11journeybama 2 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted January 30, 2016 Report Share Posted January 30, 2016 (edited) Good job. Always check fuses first. Saves a bunch of heartache waiting for someone to suggest it. Question is, why did it blow? It's likely to blow again, so start doing some troubleshooting. Pull the bulbs and check for corrosion in the terminals. Check for pinched wires. If the bulbs are original, I'd go ahead and replace them. I've had bulbs before that looked fine and worked fine but were old and used excessive current, resulting in blown fuses. Edited January 30, 2016 by jkeaton priell3, dhh3, 11journeybama and 1 other 4 Quote Link to comment Share on other sites More sharing options...
larryl Posted January 30, 2016 Report Share Posted January 30, 2016 I had to have the harness replaced into the tailgate as I had the same issue (a wire broke) dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted January 30, 2016 Report Share Posted January 30, 2016 Glad it all worked out. Take this good advice! ^^ Quote Link to comment Share on other sites More sharing options...
Constantine85 Posted December 6, 2021 Report Share Posted December 6, 2021 I was just wondering if anybody had any idea for a 2015 Dodge Journey SXT where the fuse is located is it the same as the Dodge Journey you guys have where it's the two green fuses exterior one and exterior lights to or is it fuse with the ignition I've heard from some people it's i g n 1 fuse but I just wanted to make sure if anyone has a more better rough idea on which fuse box it is first off the one underneath my passenger side – or the one underneath the hood and secondly which fuse is exactly or which fuse is it tied with. Any information that I can receive on this subject will be extremely grateful and appreciative. Happy holidays everyone God bless Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 6, 2021 Report Share Posted December 6, 2021 2 hours ago, Constantine85 said: I was just wondering if anybody had any idea for a 2015 Dodge Journey SXT where the fuse is located is it the same as the Dodge Journey you guys have where it's the two green fuses exterior one and exterior lights to or is it fuse with the ignition I've heard from some people it's i g n 1 fuse but I just wanted to make sure if anyone has a more better rough idea on which fuse box it is first off the one underneath my passenger side – or the one underneath the hood and secondly which fuse is exactly or which fuse is it tied with. Any information that I can receive on this subject will be extremely grateful and appreciative. Happy holidays everyone God bless Should be the same. What exactly is your issue? Quote Link to comment Share on other sites More sharing options...
