Flashlight
Pinger316
I have just noticed that the flashlight that is located in the cargo area in some models does not work. I don't know if I have to pull something out or what the deal is. I was wondering if anybody else had this problem too. I'm taking it in for its first oil change shortly and will ask my dealer but I was wondering if anybody else had this problem
I did, I thought I would have to have the rear end torn apart for a bad wire or something, but the fix for me was easy. Take the flashlight apart, it is pretty simple just snaps together, remove the battery and push the contacts in a little, if they are not dead on the battery the circuit inside the flashlight will not charge the battery. Might be a different problem than mine, but it worked for me.
Same thing for me. Dealer said it happens a lot. He just took the torch apart and adjusted contacts. No other work needed.
  • 9 years later...
