DirtyJourney Posted February 9, 2016 Report Share Posted February 9, 2016 I pulled my 2008 journey 3.5 into the garage yesterday. The starter needed replaced, so I unhooked the battery and changed it. Hooked the battery back up, and it fired right up. It ran for about 10 seconds then the throttle started surging. No it will only run for a few seconds. I an getting p0032, p0038,p0052, and p0058 codes. A code for the heater circuit high on all 4 o2 sensors. Don't know why these would keep it from running. Checked all my connections, cleaned battery connection and grounds. Also tried running a new ground, with no luck. Any help would be appreciated, thanks! dhh3 1 Quote Link to comment Share on other sites More sharing options...
DirtyJourney Posted February 10, 2016 Author Report Share Posted February 10, 2016 Figured out it will start right up and stay running if you keep the brake pedal engaged. As soon as you let off it surges and the engine stalls dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted February 10, 2016 Report Share Posted February 10, 2016 When you swapped the starter, which battery terminal did you disconnect? Quote Link to comment Share on other sites More sharing options...
DirtyJourney Posted February 10, 2016 Author Report Share Posted February 10, 2016 Negative, then the positive dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted February 10, 2016 Report Share Posted February 10, 2016 (edited) On 2/10/2016 at 6:17 PM, DirtyJourney said: Negative, then the positive Perfect. Rules out my thought on the possibility. On the 2008, do you have to engage the brake pedal before it will start? Edited February 10, 2016 by dhh3 jkeaton 1 Quote Link to comment Share on other sites More sharing options...
DirtyJourney Posted February 10, 2016 Author Report Share Posted February 10, 2016 What were you thinking on the battery issue before hand? Shoot my bad I meant 2009. I never had to engage the pedal before. Thanks for the reply dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted February 10, 2016 Report Share Posted February 10, 2016 (edited) If you had disconnected the positive first, you run the risk of frying the electronics. I'll word it another way. Do you have to push the brake pedal in order to start the car? On my 2011 Nitro and my 2014 DJ I have to push the brake pedal before it will start, even if they were in Park. Is your 2009 DJ like this? Edited February 10, 2016 by dhh3 Quote Link to comment Share on other sites More sharing options...
DirtyJourney Posted February 10, 2016 Author Report Share Posted February 10, 2016 I didn't have to before. I've had it running since. It was just start and stall. It got to the point where it would start right up and run fine, or it might just shut back off. I believe the whole starter thing was just a coincidence. I had a check engine light for all four of the o2 sensor heaters, output high. Also the oil light came on, which had never been on before. The o2 sensor heaters ground through the pcm. Check engine light will not shut off even after the codes are read. Immediately throws trouble codes again. I checked all the grounds, battery voltage is good, opened the harness up and all the wiring looks good. I'm suspecting a bad pcm, I'm putting one in and hauling to the dealership for reprogramming. I believe and was told by the dealership(who you can't always trust) that the skim security system is programmed into the pcm to, not just the body control module. I'm scared to try it and lock the security up. dhh3 1 Quote Link to comment Share on other sites More sharing options...
DirtyJourney Posted February 10, 2016 Author Report Share Posted February 10, 2016 No check egine, or oil light until then. I just wish I knew someone who could shed some light on the pcm, along the lines of programming and security. Info on these dj's is hard to come by dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted February 11, 2016 Report Share Posted February 11, 2016 (edited) There is a Member here, ultranuts, that bought a programmer that can get into the DJs electronics. PM him. He might be able to help you. I know little or nothing about the electronics in my DJ. That is why I purchased an extended warranty. I do not even know if it runs on High or Low Speed Bus. My Degree in Electronics can help me trouble shoot something in my mind, as to how a circuit may work, but I need to know what specific parts are on the circuit. I had my Nitro pretty much figured out, but I know nothing about my DJ. Some things may work the same way, between the two vehicles, but so far, I have had no issues with my DJ, so I am not aware of any similarities yet. Sorry. Edited February 11, 2016 by dhh3 Quote Link to comment Share on other sites More sharing options...
DirtyJourney Posted February 11, 2016 Author Report Share Posted February 11, 2016 (edited) Ok, thanks for the input. My diagnosis is the computer. Oxygen sensor heaters are grounded and regulated through the pcm. All 4 will 0xygen sensor heater circuit high output codes come up. Won't go away when cleared, also the low oil pressure light which I've never had before (yes it's full). Which all run to the same connector on the pcm. Went thru wiring harness and all looked great. Dealer is programming my new ecu today. If thar doesn't work, I'll contact ultranuts Thank you for the help. Edited February 11, 2016 by DirtyJourney dhh3 1 Quote Link to comment Share on other sites More sharing options...
DirtyJourney Posted February 11, 2016 Author Report Share Posted February 11, 2016 My genysis evo came today . I have to be at the dealership before it will be charged. My old genysis was to outdated for this car, so I had to rely on my cheap scan tool. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted February 11, 2016 Report Share Posted February 11, 2016 I'm curious as to what the Dealer may find. Weird things do happen on the DJ! Quote Link to comment Share on other sites More sharing options...
DirtyJourney Posted February 11, 2016 Author Report Share Posted February 11, 2016 Yes had put in pcm, and reflashed. Recall on keys got fixed to. Runs great with no cel on now. dhh3 1 Quote Link to comment Share on other sites More sharing options...
DirtyJourney Posted February 12, 2016 Author Report Share Posted February 12, 2016 You are very right, wierd things do happen to the DJ. I have a pretty heavy mechanical background, but the DJ has thrown a few diagnosis problems at me. Pretty easy to work on tho, as far as engine bay space and everything. I told the tech that did my programming at the my problems, and diagnosis. He said I was correct, he had seen it many times before. Just glad that it is fixed and running good. Ran a full system scan with my new genisys evo scan system, and everything is clear. Thanks! dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
