myjourneybeast Posted February 12, 2016 Report Share Posted February 12, 2016 I just bought a 2016 Journey, with a 4.3" screen, can I enable the uconnect, or is it not available? dhh3 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted February 12, 2016 Report Share Posted February 12, 2016 The Dealer you just bought it from should know. Would have been a good question to ask before you purchased it? dhh3 and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 12, 2016 Report Share Posted February 12, 2016 (edited) What does your window sticker say? What trim level do you have? Do you have the phone buttons on the left side of the steering wheel? Welcome to the forum. What does your window sticker say? What trim level do you have? Do you have the phone buttons on the left side of the steering wheel? Without detailed info we have to ask a lot of questions. Edited February 12, 2016 by jkeaton dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted February 12, 2016 Report Share Posted February 12, 2016 You can add the external module, but forgo the "Factory Look": built in microphone in the rearview mirror and steering wheel controls. You will get a stick on microphone and a little panel with the 2 buttons, which you can mount anywhere. At least this is the way it was with the last generation of radios. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted February 12, 2016 Report Share Posted February 12, 2016 (edited) I'm reasonably certain that aftermarket Mopar thing only applies to the pre-2011 Mygig radios. But what we do know is that as mentioned you cannot easily retrofit the factory package - you'd be better off trading the vehicle to get the OEM bits in and running.What I did in my last Journey was to get a Garmin 3490 GPS navigator, which has voice command that is triggered by a spoken phrase and a Bluetooth speakerphone. I put it above the rear view mirror (which made it invisible from outside) because that vehicle did not have the overhead console, leaving lots of room between the mirror and the headliner - and I fished the power cord down the right side pillar, installed a cigarette lighter socket for the traffic receiver to plug in to behind the trim and ran that power leads from the socket to the fuse block behind the glove box - you could probably have a stereo store install it for less than $50 if you aren't handy.The only drawback to the arrangement I had is that you need to turn down the stereo manually when you want to use the phone or give directions to the navigator - I considered neither to have been a hardship.The only reason I don't use that setup now is that my current DJ came with Bluetooth as part of the basic package. Edited February 12, 2016 by bramfrank dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted February 12, 2016 Report Share Posted February 12, 2016 (edited) I just bought a 2016 Journey, with a 4.3" screen, can I enable the uconnect, or is it not available? Go to this site enter your VIN number and it will give you a printable page(s) of all equipment your DJ was built with from the factory. It's found under "equipment listing". http://www.dodge.com/webselfservice/dodge/index.html?screenName=newVehicle&country=us&emailUrl=goToEmailForm%2528%2527R%2527%2529 Edited February 12, 2016 by bigtsr jkeaton and dhh3 2 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted February 12, 2016 Report Share Posted February 12, 2016 I'm reasonably certain that aftermarket Mopar thing only applies to the pre-2011 Mygig radios. But what we do know is that as mentioned you cannot easily retrofit the factory package - you'd be better off trading the vehicle to get the OEM bits in and running. Now I know! I have been enlightened. Thank you. The external module would only work on the 2009 and 2010 DJ. 2011 on have the new style radios, with the more involved Uconnect, correct? Quote Link to comment Share on other sites More sharing options...
bramfrank Posted February 12, 2016 Report Share Posted February 12, 2016 Correct dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
