probak118 Posted February 21, 2016 Report Share Posted February 21, 2016 Anyone else have the issue of your driver's window sometimes stopping halfway up ? Is this a feature if I do not hit the "auto" feature on the window up button properly? Does not happen all the time, but with the ok weather recently, I noticed it again. I put the window down again and re-try and usually it goes up all the way. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 21, 2016 Report Share Posted February 21, 2016 Not me. Never that cold around here. There is an existing thread about having to push the button twice. Quote Link to comment Share on other sites More sharing options...
bigtsr Posted February 21, 2016 Report Share Posted February 21, 2016 I would say that if your not dententing to the "auto" point of course it's going to stop but "not" at the same specific position constantly. It's possible that you may have reprogram the auto up stop point (this was posted in the past) by I believe physically holding the button to down for 1second after it reaches that position then do the same for full up. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted February 21, 2016 Report Share Posted February 21, 2016 (edited) Or, the track might require lubrication. The pinch guard may be tripping. Edited February 21, 2016 by bramfrank Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCACares Posted February 22, 2016 Official Dodge Support Report Share Posted February 22, 2016 Anyone else have the issue of your driver's window sometimes stopping halfway up ? Is this a feature if I do not hit the "auto" feature on the window up button properly? Does not happen all the time, but with the ok weather recently, I noticed it again. I put the window down again and re-try and usually it goes up all the way. Hi probak118, I looked through the Owner's Manual, and found the following. Let me know if this works. Thanks, Kathleen Top Care Specialist FCA Canada Reset It may be necessary at some point in time to reactivate the Auto-up/Auto-down feature. To do so, perform the following steps: 1. Pull the window switch up to close the window completely and continue to hold the switch up for an additional two seconds after the window is closed. 2. Push the window switch down firmly to the second detent to open the window completely and continue to hold the switch down for an additional two seconds after the window is fully open. larryl and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
probak118 Posted February 23, 2016 Author Report Share Posted February 23, 2016 Will try on the way to work, thanks everyone. Quote Link to comment Share on other sites More sharing options...
bramfrank Posted February 23, 2016 Report Share Posted February 23, 2016 Because the problem is intermittent I seriously doubt that resetting the travel will make any difference - again, I suspect the anti-pinch function is being tripped and unless they measure the required force as a function of the learn process the problem will persist. Quote Link to comment Share on other sites More sharing options...
