Zues3976 Posted February 22, 2016 Report Share Posted February 22, 2016 Installing a remote start 2014 Dodge Journey. I unplugged the inside wire harness from the fuse box to take access to bcm plugs e and f. After plugging the plugs and fuse box back in the air bag light is on and no blower motor functions to the entire cab. I have checked some of the fuses and seem to have power there. Any help dhh3 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 22, 2016 Report Share Posted February 22, 2016 make double sure when pluging them back in they got put back in correctly and seated correctly. yrs ago my son was messing around with his fuse box in his camaro and comes inside and said dad my car wont run right i went outside and got to looking and he told me what he was doing so i checked the fuses and everything looked okay i pulled some of them out and put them back in to make sure they weren't blown every thing looked okay never could figure it out, ended up taking it to a mechanic and about $300,(plugs and wires and labor) he called and said the car was fixed...ended up being one fuse on the fuel injectors when it got pushed back in, the pin had got bent just enough it was slipping behind the slot it was supposed to slid into.... so check and make sure you got all your connections right ....good luck.... dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 22, 2016 Report Share Posted February 22, 2016 Put everything back the way it was and see if that corrects the problem. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted February 22, 2016 Report Share Posted February 22, 2016 No blowers to fill up the air bags? jkeaton 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted February 22, 2016 Report Share Posted February 22, 2016 An aftermarket nightmare dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 23, 2016 Report Share Posted February 23, 2016 On 2/22/2016 at 11:44 PM, larryl said: An aftermarket nightmare And most likely voided the warranty. dhh3 1 Quote Link to comment Share on other sites More sharing options...
OhareFred Posted February 23, 2016 Report Share Posted February 23, 2016 When all else fails, have you tried the 30 min. battery disconnect to reset everything? You have nothing to lose..... dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
Zues3976 Posted February 28, 2016 Author Report Share Posted February 28, 2016 Tried the battery reset nothing happened. ****solved**** Wow is me the next day in the light and after letting my head settle. It was a fuse under the hood. A big 60 amp yellow one. Had to look into the top and see that the fusible link had melted. Lesson... disconnect the negative battery cable first before unhooking wiring harnesses in vehicle. And I've been told these computers need the negative unhooked first before the positive in order not to hurt the computer. Quote Link to comment Share on other sites More sharing options...
