Charger Posted December 25, 2016 Report Share Posted December 25, 2016 I meant to post in this thread. Not sure what I did. I bought the same light assemblies and brought them to the dealership to install. They couldn't install them because the connections didn't match. They told me I needed a wire harness to fit. But when I bought them it said it would fit a 2015 Journey Crossroad and was a plug and play and required no other wires. Any idea what is going on? Quote Link to comment Share on other sites More sharing options...
OlDirty Posted January 20, 2017 Report Share Posted January 20, 2017 On 12/24/2016 at 8:10 PM, Charger said: I meant to post in this thread. Not sure what I did. I bought the same light assemblies and brought them to the dealership to install. They couldn't install them because the connections didn't match. They told me I needed a wire harness to fit. But when I bought them it said it would fit a 2015 Journey Crossroad and was a plug and play and required no other wires. Any idea what is going on? I'd suggest turning a screw or two & seeing exactly what the dealership was talking about. I really couldn't see my local stealership even trying "such nonsense" as to install an aftermarket part. It'ii probably plug right in. Good luck Charger. Quote Link to comment Share on other sites More sharing options...
Charger Posted January 20, 2017 Report Share Posted January 20, 2017 46 minutes ago, OlDirty said: I'd suggest turning a screw or two & seeing exactly what the dealership was talking about. I really couldn't see my local stealership even trying "such nonsense" as to install an aftermarket part. It'ii probably plug right in. Good luck Charger. I ended up returning the lights and got LED bulbs instead. Cheaper and looks great. Quote Link to comment Share on other sites More sharing options...
Separate Ways Posted January 27, 2017 Report Share Posted January 27, 2017 Not sure if someone said it or not already but, if you add HID's to your projectors you won't have an issue with a short light beam.... HID's and Projectors are actually a great combination... Quote Link to comment Share on other sites More sharing options...
