Aidinbaby Posted March 8, 2016 Report Share Posted March 8, 2016 I love my journey but I've been having issues with it starting! I can be running errands and everything is fine then when I turn the key it just does a couple clicking sounds then nothing. I usually have to have someone come jump the car and that works most of the time. We have replaced the battery, altanator, ignition switch, and starter but it still happens! Any ideas of what is going on it doesn't show any error codes when read at the mechanic? Quote Link to comment Share on other sites More sharing options...
OMSmedia Posted March 8, 2016 Report Share Posted March 8, 2016 First off did you do the recall from last year...you get new keys and ignition. Second....push the stick to the right and reset park light...try to start. Last up..put a new battery in Key FOB. If still persists...a short...or a lemon law attorney is next Quote Link to comment Share on other sites More sharing options...
redtomatoman Posted March 8, 2016 Report Share Posted March 8, 2016 Totally non-mechanical comment here. Maybe the previous poster is alluding to this, but isn't there a park sensor that can be malfunctioning? The DJ won't start if it thinks it's in gear. Good luck. Peace. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
redtomatoman Posted March 8, 2016 Report Share Posted March 8, 2016 Will it start in neutral? Or if the brake is pressed more firmly? Peace. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted March 8, 2016 Report Share Posted March 8, 2016 Been posted xxx times before but tranny range selector assy or cables at the starter itself. Give me a break lemon law on a potentially 8 year old car!!! jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted March 8, 2016 Report Share Posted March 8, 2016 First off did you do the recall from last year...you get new keys and ignition. Second....push the stick to the right and reset park light...try to start. Last up..put a new battery in Key FOB. If still persists...a short...or a lemon law attorney is next I would check cables , sounds like you have a cable problem . If the starter is just clicking it's not getting enough current , a bad cable to the starter or battery would cause this. Lemon law on a 2009 car ,I think not jkeaton 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted March 8, 2016 Report Share Posted March 8, 2016 Another useless post that deserves no comments rolly 1 Quote Link to comment Share on other sites More sharing options...
