rossjenelle Posted March 14, 2016 Report Share Posted March 14, 2016 (edited) Hello, I was wondering if anyone had a labelled engine diagram for the 2.0l CRD used in 2009 Journeys. If not could you tell me what the hose in the attached picture is, the hose just to the right of the oil dipstick, the larger of the two. Thanks Edited March 14, 2016 by rossjenelle Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 14, 2016 Report Share Posted March 14, 2016 Where does it come from and where does it go? Are you referring to the vertical or horizontal one? Not familiar with the diesel, but without knowing what is it connected to, can't help much. Do you need to replace that part? Quote Link to comment Share on other sites More sharing options...
rossjenelle Posted March 14, 2016 Author Report Share Posted March 14, 2016 Righto, The hose is the one seen in the picture that is just right of the dipstick with the pronounced metal collar. It appears to travel under the horizontal hose. Looking into the engine bay it appears the hose is about 50/60cm in length before it joins to a hard plastic pipe that goes on to the front bottom right hand side (sort of looks like it finishes behind the fog light position). Unfortunately I am recuperating from some surgery and cannot get under the car to get a better look. I do need to replace it but as the CRD is as rare as chicken teeth in Brisbane there are not too many places I can go where they will know what it is. So a name means I can order online. Thanks in advance for any help. Quote Link to comment Share on other sites More sharing options...
Steve_T Posted March 15, 2016 Report Share Posted March 15, 2016 Boost hose? Quote Link to comment Share on other sites More sharing options...
pacman Posted March 15, 2016 Report Share Posted March 15, 2016 Somewhere, deep in this forum, there is a post with a link to a PDF File which I think it's what you're looking for. This is the URL http://www.gmb.be/CJD_parts/CD5/Catalogs/06-09/09jc.PDF Hope it's useful for you. rossjenelle 1 Quote Link to comment Share on other sites More sharing options...
pacman Posted March 15, 2016 Report Share Posted March 15, 2016 Boost hose? Yes, I think it's boost (turbo) hose. It's not an expensive part (less than 100 € here). rossjenelle, can you see a groove in the hose? Mine had to be replaced for that reason. Unfortunately, I didn't do it myself, and forgot to tell to the mechanic that new hose should be covered (2 layers, at least) with tape, doing so, new hose will last longer. jkeaton and rossjenelle 2 Quote Link to comment Share on other sites More sharing options...
rossjenelle Posted March 16, 2016 Author Report Share Posted March 16, 2016 Thanks everyone for their assistance, a great help and Pacman I will follow your advise and get some silicone tape onto it. Quote Link to comment Share on other sites More sharing options...
Steve_T Posted March 17, 2016 Report Share Posted March 17, 2016 For some reason I cannot reply to the other thread that you started regarding engine/part compatibility between Jeep/Dodge parts for your crd engine. In your searching, have you managed to find the correct part number that you need for the Journey? By just googling the actual part number, it should tell you other vehicles it will fit. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
