MWG Posted March 16, 2016 Report Share Posted March 16, 2016 Hi, I came back from the store and was backing into my driveway. I put it into park and then the engine revved up. I looked at the tach and it was below 1000rpm. I thought maybe my foot hit the gas pedal so I left it. My daughter was on her way out tonight for work and the same thing happened to her. She started it and the engine revved and she also noticed the rpm was below 1000. She took my car to work. I just came back from a test drive and it ran normal. There is a recall on my Journey. I can't remember the code but I think it has something to do with the ignition module. My Journey is a 2010 3.5L. Anyone have this happen to them? Thanks. dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 16, 2016 Report Share Posted March 16, 2016 Hi, I came back from the store and was backing into my driveway. I put it into park and then the engine revved up. I looked at the tach and it was below 1000rpm. I thought maybe my foot hit the gas pedal so I left it. My daughter was on her way out tonight for work and the same thing happened to her. She started it and the engine revved and she also noticed the rpm was below 1000. She took my car to work. I just came back from a test drive and it ran normal. There is a recall on my Journey. I can't remember the code but I think it has something to do with the ignition module. My Journey is a 2010 3.5L. Anyone have this happen to them? Thanks. OK, help me out here. You looked at the tach and it was below 1000. If the vehicle is in park, it should be below 1000. "the engine revved, but the tach was below 1000", are you saying the tach was not showing the RPM's correctly? As in, the engine was revving but the tack showed below 1000? dhh3 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted March 16, 2016 Report Share Posted March 16, 2016 Once again a question that has no answer dhh3 1 Quote Link to comment Share on other sites More sharing options...
MWG Posted March 16, 2016 Author Report Share Posted March 16, 2016 Since I'm not sure what the idle rpm is I said below 1000 rpm. I did say I put it in Park. So yes idle. The engine revved up without me touching the gas pedal and the tach stayed at the idle rpm. I know the engine revs when you start the vehicle then drops down to idle speed. dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 16, 2016 Report Share Posted March 16, 2016 I don't know man. Maybe try to get a video or something. I have no idea. dhh3 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted March 16, 2016 Report Share Posted March 16, 2016 If you mean that its surging it could one of many many issues from vacuum leaks to fuel pump to ecm etc etc dhh3, rolly and jkeaton 3 Quote Link to comment Share on other sites More sharing options...
