ckl Posted March 16, 2016 Report Share Posted March 16, 2016 (edited) Just a couple of days ago I noticed that somebody had busted my radio antenna. It's basically broke from the base, so the antenna mast needs to be replaced. Is the antenna easy to replace? it's a 2009 dodge journey SXT. Thanks. Edited March 16, 2016 by ckl dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 16, 2016 Report Share Posted March 16, 2016 Is it a standard antenna or a satellite equipped one? dhh3 1 Quote Link to comment Share on other sites More sharing options...
Steve_T Posted March 17, 2016 Report Share Posted March 17, 2016 Are you sure it didn't happen by going through a car wash? Used to happen all the time on VW's, brushes or dryer vents come down and grab the antenna, which in turn gets tangled and mangled. dhh3 1 Quote Link to comment Share on other sites More sharing options...
OhareFred Posted March 18, 2016 Report Share Posted March 18, 2016 My 09 antenna broke in the car wash. Dealer replaced under warranty but it required the headliner being removed. Any chance you can use a broken screw extracter to remove whats left of the screw? Then u can just get the replacement antenna and screw it in..a word to the wise, I now always unscrew the antenna before using any car wash.... QuarterSwede and dhh3 2 Quote Link to comment Share on other sites More sharing options...
pacman Posted March 18, 2016 Report Share Posted March 18, 2016 Anyone of you are considering mounting a shark fin antenna? I suppose it won't work for satellite radio, but for AM/FM shouldn't be any problem. They're pretty cheap at Ebay or similar webs (yeah, China manufactured), and that's why I'm not sure how well they work. I don't want to mount an antenna which, when I'm driving at highway, I can't listen to my favourites radio stations, and it's fixed to the car roof with a sticker at the bottom, so, if you remove it, what will happen with the paint? dhh3 1 Quote Link to comment Share on other sites More sharing options...
ckl Posted March 18, 2016 Author Report Share Posted March 18, 2016 It's a satellite equipped antenna. I always wash the car by hand and have never gone through a car wash. I got it replaced at the local mechanic. Thanks. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted March 18, 2016 Report Share Posted March 18, 2016 FYI. The base of the antenna is the Sirius antenna. The mast is only for AM/FM. Quote Link to comment Share on other sites More sharing options...
ltdjourney Posted March 19, 2016 Report Share Posted March 19, 2016 I installed a shark fin on mind worked awesome it fits right on over and looks great. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted March 19, 2016 Report Share Posted March 19, 2016 How is the reception? How do you hook it up? Quote Link to comment Share on other sites More sharing options...
ltdjourney Posted March 20, 2016 Report Share Posted March 20, 2016 It had a wire inside with a small bolt ,but sometimes the bolt may not fit so go auto shop antenna to size bolt . The reception was great,It fit on over the base with two way tape . It didn't come of going through car wash. dhh3 1 Quote Link to comment Share on other sites More sharing options...
