mavericks Posted April 20, 2016 Author Report Share Posted April 20, 2016 Are you adjusted, using line on the wall? Or went to garage and adjuted, using professional tool?Can you please add pictures, before and after adjustments? I did the adjustment using the wall, sorry just saw your post, so cant post pictures before adjustment. Right now they look good. Quote Link to comment Share on other sites More sharing options...
Camper Posted April 20, 2016 Report Share Posted April 20, 2016 Lots of adjustment, or just a bit? Quote Link to comment Share on other sites More sharing options...
Camper Posted April 20, 2016 Report Share Posted April 20, 2016 Did you replaced high beam as well? or just a low beam? what about fog lights, replaced then to? Quote Link to comment Share on other sites More sharing options...
mavericks Posted April 20, 2016 Author Report Share Posted April 20, 2016 Lots of adjustment, or just a bit? Took 10 minutes, Just adjusted the focus and everything looks good now.. Quote Link to comment Share on other sites More sharing options...
mavericks Posted April 20, 2016 Author Report Share Posted April 20, 2016 Did you replaced high beam as well? or just a low beam? what about fog lights, replaced then to? Just the low beams. Planning to change my fog lights soon .not right now though. For high beams i have the OEM Cody Chornobey Powley 1 Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted April 20, 2016 Report Share Posted April 20, 2016 Not sure where you get the idea of having to aim m projectors down lol. They are at the exact same height as stock! If anything has to be adjusted its the projector its self, stock lights I parked 25 feet away from my garage marked my lights after the retrofit go back to the wall at 25 feet and put them in the same spot didn't lose any distance if anything I gained a massive amount and width its crazy, on a highway I light up five lanes wide, the step in my cut off is for on coming traffic #winning Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted April 21, 2016 Report Share Posted April 21, 2016 Panamera led drl in my headlights with mini h1 7.0 6500k xb hid bulbs, in my fogs I have xsb switchback turn signals mavericks, OlDirty and R4V3N 3 Quote Link to comment Share on other sites More sharing options...
mavericks Posted April 21, 2016 Author Report Share Posted April 21, 2016 Panamera led drl in my headlights with mini h1 7.0 6500k xb hid bulbs, in my fogs I have xsb switchback turn signals Fog lights are really cool. How much did you spend on them?? I might be interested. Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted April 21, 2016 Report Share Posted April 21, 2016 These are custom I have projectors in my fogs with switchback halos, 300 for projector bulbs hid ballast switchback halo Quote Link to comment Share on other sites More sharing options...
Camper Posted April 21, 2016 Report Share Posted April 21, 2016 LED bulbs for for way chipper, it only cost $35.00. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted April 22, 2016 Report Share Posted April 22, 2016 When it comes to my personal lighting I like my projectors with hid, my gallery speaks for itself on what i prefer for lighting performance wise, hid projectors will out perform one led bulb in a housing, now led projector on the other hand is damn close to hid projector in performance, those led bulbs you see online that say projector led are nonbetter than, a flashlight Quote Link to comment Share on other sites More sharing options...
R4V3N Posted April 22, 2016 Report Share Posted April 22, 2016 Panamera led drl in my headlights with mini h1 7.0 6500k xb hid bulbs, in my fogs I have xsb switchback turn signals Sweet setup! Am also running HID projector lights and will never go back. Am sure LEDs are cheaper, is it brighter? Does anyone have a comparison? My fogs are JW speaker. Cody Chornobey Powley 1 Quote Link to comment Share on other sites More sharing options...
Camper Posted April 22, 2016 Report Share Posted April 22, 2016 At least all this modifications, do not void warranty:"NON-FCA MODIFICATIONS The warranties in this booklet do not cover repairs required because of non-FCA modifications,installation of special equipment or accessories, or use of special materials, fuels or additives. Thisincludes special bodies, body conversions, fuel system conversions, trailer hitches, window tints,sunroofs, theft alarms, etc. Non-FCA modifications do not by themselves void your warranty, but theyare not covered by your warranty."""""""""" R4V3N 1 Quote Link to comment Share on other sites More sharing options...
Camper Posted June 5, 2016 Report Share Posted June 5, 2016 Just replaced all headlights bulbs with LED ,on my 2016 crossroad, hi beam and DRL working without any issue, as fog lights as well. However, low beam is different story. The lights, is turned on, then right side light turned off, 10-15 min, later left side turned off. Added resistor to both sides, right side do not light up at all, after that, but left side still working fine. This is what I installed for low beam:Atshark 80W 7200LM 9006 LED Headlight / Headlamp Conversion Kit 3 COB LED 6000K Cool White Super Bright- Replaces Halogen & HID-2 Pack Any idea, what it can cause this? Any one run on this problem? Quote Link to comment Share on other sites More sharing options...
Camper Posted June 5, 2016 Report Share Posted June 5, 2016 Even with resistor, left side low beam goes off after 15 min off ride.Just removed both resistors from both sides. Maybe some one can point to solution. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 6, 2016 Report Share Posted June 6, 2016 Sounds like bad bulbs. I've been running LED's in low and high beam for about 6 months now no issues at all. Don't get high beamed by other drivers either. Quote Link to comment Share on other sites More sharing options...
Camper Posted June 6, 2016 Report Share Posted June 6, 2016 Same light bulb, working on high beam, without any issue (: Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 6, 2016 Report Share Posted June 6, 2016 Same light bulb, working on high beam, without any issue (: The low and high beams are different bulbs. Quote Link to comment Share on other sites More sharing options...
Camper Posted June 6, 2016 Report Share Posted June 6, 2016 That is correct, I just swap them for testing. I think the issue with the "driver", I will try to swap the "drivers" from hi beam to the low beam and will see if it working that way. Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted July 10, 2016 Report Share Posted July 10, 2016 Morimoto h1 projector high and low beam 6500k @35 watt OlDirty and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
OlDirty Posted January 29, 2017 Report Share Posted January 29, 2017 On 7/10/2016 at 9:11 AM, Cody Chornobey Powley said: Morimoto h1 projector high and low beam 6500k @35 watt  Dammit Cody! You're going to convince me to do this mod if you keep post pics like these. lol Yeah! I'd sure as hell hate to be the sucker that flashes you on that dark road.... Quote Link to comment Share on other sites More sharing options...
Bryman31 Posted September 3, 2017 Report Share Posted September 3, 2017 On 4/12/2016 at 7:15 PM, jkeaton said: These. 60 w http://www.amazon.com/YITAMOTOR-White-Headlight-Conversion-Bulbs/dp/B017LW2V42?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00   just curious its been over a year.....how are these holding out? still recommend? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted September 3, 2017 Report Share Posted September 3, 2017 Absolutely. Quote Link to comment Share on other sites More sharing options...
