sidney john Posted April 18, 2016 Report Share Posted April 18, 2016 Hi everyone.. need help here please..i have a dodge journey 2012 with 71k milleage unfortunately my wheel bearing driver side give up and i change it by myself, after installing the new bearing and have it for drive check suddenly the 3 lights warning went on (ABS, TRACTION CONTROL,SERVICE AWD) i dont know what i did wrong..please anybody has a similar issue like mine that can help me determine the problem..thanks in advance dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 18, 2016 Report Share Posted April 18, 2016 If you did not plug in the sensor properly, the car will have no idea at what rate each wheel is turning. Hence, no AWD, ABS, TC and I'll bet that your Cruise will not work either. 2late4u and John/Horace 2 Quote Link to comment Share on other sites More sharing options...
sidney john Posted April 18, 2016 Author Report Share Posted April 18, 2016 yes i did, was install properly thats why i can't figure out whats the cause of lights on on my dash dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 18, 2016 Report Share Posted April 18, 2016 Unplug the sensor, and make sure you did not bend a pin. They are touchy. Then disconnect the negative terminal of your battery for about 30 minutes to reset your system. See what happens. OhareFred, 2late4u and sidney john 3 Quote Link to comment Share on other sites More sharing options...
Shawn Patrick Smith Posted December 25, 2017 Report Share Posted December 25, 2017 On 4/18/2016 at 12:49 PM, sidney john said: yes i did, was install properly thats why i can't figure out whats the cause of lights on on my dash I have these lights on my dash. I am not sure whats going on but the car has been running fine since I got the car in 2016 brand new. the lights came on yesterday when I went to go out, thinking it was because of the snow and ice build up in the wheel well I cleared that out and tried shutting down and restarting the car, lights went out. went to go out last night and they came on, so I stopped shut it off and started lights went out then came on after I drove a little bit. went home instead of testing the limits. came out to snow blow the drive way, started car only 2 lights ABS and TC came on. moved the car to the street and lights went out. went to go fill the car up with gas and because the street hasn't been plowed yet, theres still quite a bit of snow on the street so when the traction control kicked in car lost some power and then the 3 lights came on again, awd no abs and when the tc light comes on it loses power unless I turn the TC off and only the front wheels spin. because of the holidays the dealer ship is closed. does anyone know if this would be safe to drive until I get it into service? Quote Link to comment Share on other sites More sharing options...
larryl Posted December 25, 2017 Report Share Posted December 25, 2017 I would take a picture of your dash showing the lights so when you take it the dealer you can show them what it is doing Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 26, 2017 Report Share Posted December 26, 2017 Yes it is safe to drive. Quote Link to comment Share on other sites More sharing options...
Ziyad thaher Posted July 4, 2020 Report Share Posted July 4, 2020 I have the same problem. Did you fix it? How? Quote Link to comment Share on other sites More sharing options...
Machew Posted September 7, 2020 Report Share Posted September 7, 2020 Did anyone fix this for knows how? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted September 7, 2020 Report Share Posted September 7, 2020 Scan for codes to figure out which abs wheel sensor is bad. Then replace sensor and reset with scanner. Summer Solstice, 2late4u and jkeaton 3 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted September 8, 2020 Report Share Posted September 8, 2020 What he said ^^^^ Quote Link to comment Share on other sites More sharing options...
SWright Posted March 26, 2022 Report Share Posted March 26, 2022 On 4/17/2016 at 9:01 PM, sidney john said: Hi everyone.. need help here please..i have a dodge journey 2012 with 71k milleage unfortunately my wheel bearing driver side give up and i change it by myself, after installing the new bearing and have it for drive check suddenly the 3 lights warning went on (ABS, TRACTION CONTROL,SERVICE AWD) i dont know what i did wrong..please anybody has a similar issue like mine that can help me determine the problem..thanks in advance I know you probably have fixed your problem but this just happened to me for no reason. All systems seemed go so before I connected my OBD reader I tried the trick used for resetting the oil change reminder. Turned the car to run, but do not start it, pressed the accelerator pedal three times holding it down for one second each time. Turned the car off and then restarted it and the trouble codes went away and the cruise control started working. It did not happen again. I am assuming there was something on the sensor and it threw the code when we first started the car. Until reset it stayed on. Once reset it did not return. Just a shot in the dark for you. I got lucky. Quote Link to comment Share on other sites More sharing options...
