Brake pedal floating
2011 dodge journey awd. Upgraded the front brakes to 2013 brakes. New master cylinder and new rear calipers and brakes. New front calipers and brakes. has 90,000 miles and the pedal is not as firm as it use to be before the upgrade.The pedal is pushed down the floor quite easily pressure is not as high as it was before. Brake fluid in the master will be high one day and next day it will be little lower and next it will be back where it was. The boot on the cap was sucked out and I had to push it back in. Air in the lines? Any ideas?
