2009 dodge journey awd Posted April 21, 2016 Report Share Posted April 21, 2016 I have a problem with my 2009 dodge Journey sxt 3.5L awd. The engine idle is not constant at stop and in reverse while holding the brake. the idle surges from a normal idle to a lower idle. the vehicle does not stall nor does it shake or vibrate. took for the throttle body and clean it. it looks like the IAC ( Idle air control valve) and TPS ( throttle positioning sensor) is one unit , all tied within one medal body. so I can't clean the IAC nor can I replace the TPS if the may be the issue/ problem. Or can this throttle body be open up? Any ideas what may be making the idle issue. No codes showing. also put a can of injector cleaner and can of water remover in the tank. still no luck with the fix. Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 21, 2016 Report Share Posted April 21, 2016 Does it do it all the time, hot or cold? Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 21, 2016 Report Share Posted April 21, 2016 run a couple of bottles of chevron gas treatment thur your gas tank before tearing anything apart. it keeps my truck running great as i dont drive it a lot it is what my mechanic recommended to do every 6 months or so worth a try.... dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 21, 2016 Report Share Posted April 21, 2016 x2 ^^ Chevron Techtron is a great product. aukfan33 1 Quote Link to comment Share on other sites More sharing options...
2009 dodge journey awd Posted April 21, 2016 Author Report Share Posted April 21, 2016 dhh3 , the idle started after warn up, then gets a little wers as it be hotter. It did stop for a bit one day but came back. dhh3 1 Quote Link to comment Share on other sites More sharing options...
2009 dodge journey awd Posted April 21, 2016 Author Report Share Posted April 21, 2016 2late4u thanks, I"ll try some gas treatment , chevron gas treatment . I have already put in a can of water remover and fuel injector cleaner ,does the cheven treatment do anything different. dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 21, 2016 Report Share Posted April 21, 2016 How many miles? When was your last tune up? dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 21, 2016 Report Share Posted April 21, 2016 Chevron TechTron is just a superior product. It is amazing how it will clean the entire fuel system, especially the injectors. I swear by it. It cots more, but it is worth it. Quote Link to comment Share on other sites More sharing options...
2009 dodge journey awd Posted April 22, 2016 Author Report Share Posted April 22, 2016 177.200 kms which equals around 110.000 miles, would know when It had it's last tune up. but I haven't tune it up since I bought it at 113000 kms/ 66.000 miles. just changed oil avery 10.000 kms and air filter twice a year. put a can of Chevron tonight. I'll see what it does. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 22, 2016 Report Share Posted April 22, 2016 It may take a couple of tries to get the injectors squirting a uniform spray pattern, depending on how much crud is lodged in them. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 22, 2016 Report Share Posted April 22, 2016 It may take a couple of tries to get the injectors squirting a uniform spray pattern, depending on how much crud is lodged in them. agree with dhh3 run several cans of it thur with different tanks of gas took time building up and will take some time getting them clean if it works might be to gunked up and require injector cleaning. dhh3 1 Quote Link to comment Share on other sites More sharing options...
2009 dodge journey awd Posted April 23, 2016 Author Report Share Posted April 23, 2016 ok thanks. dhh3 1 Quote Link to comment Share on other sites More sharing options...
aukfan33 Posted April 23, 2016 Report Share Posted April 23, 2016 Have the spark plugs been changed? They should've been changed out at 100,000 miles. 2late4u and dhh3 2 Quote Link to comment Share on other sites More sharing options...
2009 dodge journey awd Posted April 23, 2016 Author Report Share Posted April 23, 2016 No, I was thinking about the plugs also, I guess /or would the plugs make the idle run at normal 600rpm and surge to 900rmp when backing up or having the break on at stop or idleing in park. it only does this when the DJ is warm. and it does it intermittently aver 5 secs. I guess it wouldn't hurt to remove the plugs. do I have to install the same plugs as the one on the DJ or can I just get cheaper ones. Also would the PCV value also make this happen . i don't think the PVC value has ever been changed. Dusty256 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 23, 2016 Report Share Posted April 23, 2016 i would use only the plugs what the car calls for, and even for what little the plugs would cost if they are easy to do i would do that also in a heart beat as if you take the car into a shop that will be the first thing they will want to do anyways.. dhh3 1 Quote Link to comment Share on other sites More sharing options...
OhareFred Posted April 24, 2016 Report Share Posted April 24, 2016 The timing belt should have been changed around 100,000 miles also. While you are changing the timing chain, might want to replace the water pump while your in there. 100,000 miles is an expensive maintiance milage mark. Plugs, timing belt/chain, water pump. Likely around $1,500.00 US $. If you take it to a shop. Must remove intake manifold to change the plugs. The water pump is internal, so you may as well swap it while your in there changing the timing belt/chain...,,. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted April 24, 2016 Report Share Posted April 24, 2016 110,000 miles it's overdue on plug changes and timing belt too , might as get everything as recommend in the owners manual .. you don't want the timing belt to let go ... dhh3 1 Quote Link to comment Share on other sites More sharing options...
2009 dodge journey awd Posted April 25, 2016 Author Report Share Posted April 25, 2016 DJ stop idle issues for a bit yesterday ,then stated up again revving from 600rmp to 900rpms off and on. It seems to do this more when I have driven longer ( engine fan ways going on but the idle problem continues with fan not running also and engine hot (temperature gauge is needled at half way point) also on second tank of gas with another can of chevron. I know it's time for plugs.But the dj run great around town no miss and on highway plenty of power. no stalling or vibration on idle non any hesitation when put in driver. dhh3 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted April 25, 2016 Report Share Posted April 25, 2016 Do the plugs, timing belt before its to late cheaper than a rebuild dhh3 1 Quote Link to comment Share on other sites More sharing options...
2009 dodge journey awd Posted April 25, 2016 Author Report Share Posted April 25, 2016 Re: plugs . Went to Canadian tire yesterday and inquired about plugs for the dj. they had two types ( champion that are gaped at .045) and a nother kind at .053 gap.) if i buy the plugs what should I gap them at or are they per gaped for the v6 3.5Liter engine. Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 25, 2016 Report Share Posted April 25, 2016 why not check with your DODGE dealership they will have all your answers that you will know IS correct instead oh hearsay, not trying to be negative as there is a lot of good advice here but you need to be 100 percent sure of the answers to your questions ..... dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 25, 2016 Report Share Posted April 25, 2016 I would definitely change the timing belt. The 3.5/4.0 is an odd duck of an engine. There are 24 valves but only SOHC. Most multivalve engines are DOHC. You might want to check and see if this engine is an interference design: if the timing belt breaks, the pistons will hit the valves and bend them. Then, it will be time for a valve job and possible piston replacement. If it is a non-interference design, the pistons and valves will not touch if the timing belt breaks. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
