Hankster Posted April 26, 2016 Report Share Posted April 26, 2016 I have noticed an issue over the last couple of weeks with our new to us 2.4 Journey. During damp rainy weather we get a stumble when doing a stop and go at stop signs. It felt a bit like when you would come to a stop without pushing the clutch in on a manual shift. Then when accelarating it would stumble and do a rough down shift. Hank Quote Link to comment Share on other sites More sharing options...
Hankster Posted April 26, 2016 Author Report Share Posted April 26, 2016 Earlier today I decided to take a look at the spark plugs and air filter and for any vacuum leaks. I found worn out plugs and a dirty filter. This car only has 80,000kms. I installed 4 new ngk irridium plugs and a new air filter, runs so much better now and generally smoother. Hank OhareFred 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 26, 2016 Report Share Posted April 26, 2016 wonder if it was the first air filter change hope not...... dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 26, 2016 Report Share Posted April 26, 2016 Got to keep up the maintenance. I don't know how many mikes 80,000 Kms is, but the 2.4 needs new plugs every 30,000 miles. 2late4u and dhh3 2 Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 27, 2016 Report Share Posted April 27, 2016 about 50 k miles dhh3 1 Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted April 27, 2016 Report Share Posted April 27, 2016 the 2.4 use's copper plugs with 30,000 mile change .. stumbling when wet out points to coils and or boots . Carbon tracking on the plugs and boots. last plug change I put champions in it and I can tell the difference . some hesitation etc so going to put KGK plugs in .. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Hankster Posted April 27, 2016 Author Report Share Posted April 27, 2016 No carbon tracks that I could see. I think the air filter and plugs were the originals. Really like the way this runs and drives now. When the weather clears I want to check out the battery to see what supprises wait for me there. Hank dhh3 1 Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted April 27, 2016 Report Share Posted April 27, 2016 one reason copper plugs . dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 27, 2016 Report Share Posted April 27, 2016 The 3.7 in my Nitro also called for copper plug changes every 30,000 miles. The reason for this: the heat at which the copper plugs burn to keep carbon deposits from forming in the plastic intake manifold. May be the same thing in the 2.4. If the engine calls for copper plugs, that is what I would use. It may run fine now with the iridium plugs, but you are only asking for trouble down the line. jkeaton and Hankster 2 Quote Link to comment Share on other sites More sharing options...
Hankster Posted April 27, 2016 Author Report Share Posted April 27, 2016 Thanks for the input I will try them and see.I have had good luck with double platinum in my 3.3 Caravans and older 2.2 and 2.5 shadows. Hank Animal Mother and dhh3 2 Quote Link to comment Share on other sites More sharing options...
bfurth Posted April 27, 2016 Report Share Posted April 27, 2016 Copper plugs are about 1/3rd the cost of platinum or iridium plugs, but only last about 1/3rd as long. If you're changing the plugs on your own (and for this engine, unless you are REALLY bad at turning a wrench, you should be), the only difference is the 20 minutes every 30,000 miles it should take to change them out. Also, by using "not what is listed as an OEM part," you run afoul of the powertrain warranty and any future issues with engine performance or emissions can be blamed on a non-factory-approved part to void a warranty claim. Many engineers spent substantial amounts of time determining what the best spark plug is for this (and any other) engine. Unless your level of education in engineering exceeds theirs, it's probably best to stick with what they recommend. Or do what you want, it's your car. dhh3, jkeaton, 2late4u and 1 other 4 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 27, 2016 Report Share Posted April 27, 2016 Believe me. Stick with copper core and change every 30k. The 2.4 in our 09 ran like a top for 80,000 miles. Hankster, 2late4u and dhh3 3 Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted April 27, 2016 Report Share Posted April 27, 2016 Believe me. Stick with copper core and change every 30k. The 2.4 in our 09 ran like a top for 80,000 miles. plus the 2.4 has got to be the easiest plug change on any engine I have ever had . they are right there on top . pull four coil packs with boots and take em out .. Animal Mother, priell3 and dhh3 3 Quote Link to comment Share on other sites More sharing options...
Hankster Posted July 8, 2017 Author Report Share Posted July 8, 2017 Update, the stumble and hesitation has been gone for over a year now, but has again started to do it. I found a couple of reasons first aluminum grit in the throttle body that seemed to be interfering with the throttle plate. The grit was from corrosion between the housing and the rubber air pipe. It was an easy job to pull out and clean.Second I also pulled the year old iridium spark plugs and put the specified nickel plugs obtained from my dealer. The driveability has improved and this car now runs smoother that I thought possible.If you are having hesitation, stumbles, bad shifting this definitely is worth a look. I had to go to the dealer for the proper spark plugs all the part stores in my area all recommended Iridium or platinum spark plugs for this engine even though they are not apparently compatible and only lasted 20,000kms. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
