RDLasaiter Posted May 2, 2016 Report Share Posted May 2, 2016 I blew a fuse on my 2013 Journey. I found the interior panel and pulled the fuse for the center console. I believe that it is F103. I attempted to plug in a new fuse, and it won't stay. I moved an existing plug, it won't stay. The new plugs and the one I swapped all work on other ports, but this one, nothing will stay in. It's loose, like the inside that holds the fuse blades is gone. Anyone have an idea? Attempted to hold the blade in place with tape, didn't work. Quote Link to comment Share on other sites More sharing options...
RDLasaiter Posted May 3, 2016 Author Report Share Posted May 3, 2016 Figured it out. Nothing wrong with the slot. The issue was between my ears and with my eyes. For some reason, I kept trying to plug the fuse back into the "spare" slot. The spare slot never held a spare, and it ain't spare. It's a spare slot that has no receptacle on the other side of the plastic. That is why it would never plug in. If your diagram calls it a "spare", then there needs to be a spare, or it needs to be a spare slot. Instead, it's a BLANK spot. dhh3 1 Quote Link to comment Share on other sites More sharing options...
