Unclemarker Posted May 9, 2016 Report Share Posted May 9, 2016 (edited) 2012 R/T AWD,when i come to a stop while still in drive with my foot on the brake and turn the wheel both ways i get a snapping /creaking sound. Also when i go over a speed bump in a parking lot with foot on the brake i get a slight scrapping sound ,but when i go over the speed bump without touching the brakes there is no sound.Had strut assembly replaced on both sides and both sway bar links have been done .Still have the sounds,any idea's ? Edited May 9, 2016 by Unclemarker dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted May 9, 2016 Report Share Posted May 9, 2016 CV joints Quote Link to comment Share on other sites More sharing options...
larryl Posted May 9, 2016 Report Share Posted May 9, 2016 Are the lug nuts tight? dhh3 1 Quote Link to comment Share on other sites More sharing options...
Unclemarker Posted May 10, 2016 Author Report Share Posted May 10, 2016 Animal Mother? Animal Mother and dhh3 2 Quote Link to comment Share on other sites More sharing options...
Unclemarker Posted May 10, 2016 Author Report Share Posted May 10, 2016 thanks dhh3,i'm thinking the same thing.yes larryl the lugs are tight but thanks for the idea.Animal Mother,i did look and read alot of posts and most had a different sound then i was stating. I'm just trying to find help in here so why dont you piss off jkeaton and dhh3 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 10, 2016 Report Share Posted May 10, 2016 (edited) 2012 R/T AWD,when i come to a stop while still in drive with my foot on the brake and turn the wheel both ways i get a snapping /creaking sound. Also when i go over a speed bump in a parking lot with foot on the brake i get a slight scrapping sound ,but when i go over the speed bump without touching the brakes there is no sound.Had strut assembly replaced on both sides and both sway bar links have been done .Still have the sounds,any idea's ? Is it possible for you to have someone sit in the car with their foot on the brake, turning the wheel back and forth and you stand outside and try to pinpoint the sound? Edited May 10, 2016 by jkeaton dhh3 1 Quote Link to comment Share on other sites More sharing options...
Unclemarker Posted May 10, 2016 Author Report Share Posted May 10, 2016 Hi jkeaton i'm taking it in for alignment this afternoon and will see if i can get them to listen to it for sure.When i find out what it is i'll let you guys know.Have a good day ! jkeaton and dhh3 2 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted May 10, 2016 Report Share Posted May 10, 2016 Check the boots on the CV joints. Make sure that there are no rips or tears. If you start to lose the grease, the CV joints are not long for this world! jkeaton 1 Quote Link to comment Share on other sites More sharing options...
JohnnyRevs Posted May 25, 2016 Report Share Posted May 25, 2016 I had a different problem on my car. Problem was that my brake caliper was missing 1 of the copper shims that allow the pads to slide smoothly and keep them tight in the caliper - this caused more of a rattle than a scraping noise but was only noticeable over rough surfaces. Rather than replace the entire caliper, I managed to modify one from an old Toyota caliper. Probably not your problem but can't hurt to check. dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
