Jeremiahrenee2009 Posted May 12, 2016 Report Share Posted May 12, 2016 My battery light went on ,had the charging system checked it was only a bad battery around that same time my radio would stay on I can not find a fix even after new battery Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted May 13, 2016 Official Dodge Support Report Share Posted May 13, 2016 Welcome to the forum! The first thing I would recommend is ensuring that your Uconnect software is current. You can check for that here: https://www.driveuconnect.com/software-update/- Jack, Dodge Social Care Specialist jkeaton 1 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted May 13, 2016 Report Share Posted May 13, 2016 Not shutting off has never been an issue for these radios as far as I know. Ever. So that implies that the revision of the firmware is not a likely culprit. I suppose that something might have glitched some code somewhere in the vehicle - it might not even be in the radio, however. In any case reloading the radio firmware - even the same version - won't hurt and might solve the problem.But when you say 'won't shut off', do you mean that the radio stays on overnight? Does it shut off with the battery rundown protection? Is it the radio? Or is it that everything in the accessory power system (lights on the start button stay lit)? Jeremiahrenee2009 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
Jeremiahrenee2009 Posted November 17, 2016 Author Report Share Posted November 17, 2016 (edited) It stays on about five minutes , it all started after my alternator went out and ,I replaced it with a new battery ,I did look up my firmware and it is up to date,my delay setting is on 0 seconds,I also looked at the door wiring harness and there are no broken wires Edited November 17, 2016 by Jeremiahrenee2009 Quote Link to comment Share on other sites More sharing options...
