Brian Bell Posted May 23, 2016 Report Share Posted May 23, 2016 Bought this DJ a few months ago, did not purchase extended warranty (couldn't afford it), bought it with 104k miles. Ran good during test drive, no issues. Changed oil/filter a few days ago, went to start it up yesterday (it had been driven after oil change with no issues), engine sputters and dummy light flashed 23 times, then on steady. Engine allowed to come up to 190,degrees, all fluid levels are normal, but engine continues to sputter. Any clue what could have happened? I don't feel comfortable driving into town (we live 10 miles out), and I ordered a scanner that should be here tomorrow. Bought this thing in Feb and the wife wants to get rid of it....... dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 23, 2016 Report Share Posted May 23, 2016 Can't help you until you post the code. You can take it to an auto parts store and get them to read it for you, dhh3 1 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted May 23, 2016 Report Share Posted May 23, 2016 You may have bought some bad gas. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted May 23, 2016 Report Share Posted May 23, 2016 (edited) codes will tell all. could be anything , if the check engine light is flashing then you have a miss fire . plugs and coils first come to mind.. when was the plugs changed last ...would change them as the 2.4 plugs need to be changed every 30,000 miles . a scanner will tell you which clyd is missing .. also a bottle of chevron fuel system cleaner can't hurt .. just dump it in a near empty tank and fill up . that little 2.4 is a great engine , lacks a little on the horsepower end but loves to be run ... Edited May 23, 2016 by Dusty256 jkeaton, dhh3 and OhareFred 3 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted May 23, 2016 Report Share Posted May 23, 2016 Welcome to the forum. Did you get a service history on the vehicle? Quote Link to comment Share on other sites More sharing options...
Brian Bell Posted May 24, 2016 Author Report Share Posted May 24, 2016 I'll post the code when I get the scanner tomorrow. I contacted the dealership I bought it from, it might still be under the powertrain warranty. I should get a call tomorrow. Hopefully I can get this sorted soon. Although I don't plan on taking this to it, I have a funeral to attend about 5 hours away and don't want to leave my wife and kids with it like this. dhh3 1 Quote Link to comment Share on other sites More sharing options...
bfurth Posted May 24, 2016 Report Share Posted May 24, 2016 Spark plugs won't be covered under the powertrain warranty - they're a maintenance item at 30k miles. It's also an $8 fix for 20 minutes of your own time. And don't change them out when the engine is hot - you run the risk of damaging the threads. dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted May 24, 2016 Official Dodge Support Report Share Posted May 24, 2016 I'll post the code when I get the scanner tomorrow. I contacted the dealership I bought it from, it might still be under the powertrain warranty. I should get a call tomorrow. Hopefully I can get this sorted soon. Although I don't plan on taking this to it, I have a funeral to attend about 5 hours away and don't want to leave my wife and kids with it like this. If you end up taking the vehicle to the dealer and need assistance, let me know. - Kevin T, Social Connect Team dhh3 1 Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted May 24, 2016 Report Share Posted May 24, 2016 spark plugs are such a easy swap you might as well go ahead and replace them ... be sure to get recommend NGk plugs the motor is happier with them in there dhh3, jkeaton and 2late4u 3 Quote Link to comment Share on other sites More sharing options...
2late4u Posted May 24, 2016 Report Share Posted May 24, 2016 104 k ,miles no power train warranty there unless they gave you a 30 day warranty or whatever is listed on for sales form. 5yr 100k on powertrain from dealership dhh3 1 Quote Link to comment Share on other sites More sharing options...
Brian Bell Posted June 23, 2016 Author Report Share Posted June 23, 2016 Sorry guys, lost some friends in a car accident and I totally forgot about this post. Forgive me for not having the details, but I took it to a mechanic and was told that it was a wiring harness. The harness replaced and the rough run disappeared. Everything seemed to be going along fine but then the hesitation/sputtering came back. It is the same sputtering in low rpm that it did before the wiring harness went out. It feels like bad gas or water in the lines, but it only doe sit in low rpm (first gear or going up hill, even in cruise control). I bought a cheap obdII but it isn't reading the vehicle. I have plugged it into my other two vehicles and it reads out no problem, but when I plug it into the dj it just hangs at "waiting for vehicle". I am at the point where I will be taking it to the dealership to see if they have any idea, but I am not trying to spend much more on it. The wiring harness job was $240 which isn't too much, but on a teacher's salary it is more than I like to spend on a vehicle we haven't yet owned for a year....... dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 23, 2016 Report Share Posted June 23, 2016 Sorry to hear about the loss of your friends. I hope the dealer can get it figured out. Strange about the code reader. dhh3, OhareFred and Brian Bell 3 Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 23, 2016 Report Share Posted June 23, 2016 any parts store can check for codes for you for free, quick way to see if its your scanner or something with the journey, what about the plugs did you change them????also my daughters caravan had a problem something like you are talking about and one mech. finally found it. it was the connector was shorting out inside the plug that was connecting to her coil....he replace that plug and it fixed her problem of course that was after a set of plugs and plug wires and replacing 3 ign coils and about $400 in labor charges between the dealership and then his place of business good luck.... dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted June 24, 2016 Report Share Posted June 24, 2016 What harness did they replace? Quote Link to comment Share on other sites More sharing options...
