sputnik Posted May 27, 2016 Report Share Posted May 27, 2016 Hello learned members....I am seeking some advice for my Dodge Journey 2014 CrossRoad with 15000 kms on it! For the past 2 weeks, I have noticed that whenever I turn left there is a slight clicking noise coming from the front end. The frequency is higher the more I steer to the left Only maintenance performed was swapping winter to summer tires about a month ago. Can someone please help me understand, what I should focus on before I call the dealership I have extended warranty so hopefully it should be covered. Any advice will be greatly appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
Camper Posted May 27, 2016 Report Share Posted May 27, 2016 Check the lugs on both front tires, maybe you get some loose. Journey_SeXT and dhh3 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 27, 2016 Report Share Posted May 27, 2016 (edited) Struts, loose lug nuts, CV joints, could be anything. Edited May 27, 2016 by jkeaton dhh3 and Journey_SeXT 2 Quote Link to comment Share on other sites More sharing options...
sputnik Posted May 27, 2016 Author Report Share Posted May 27, 2016 Thanks guys....will take a look! dhh3 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted May 27, 2016 Report Share Posted May 27, 2016 should still be under factory warranty take it to the dealer if so.good luck dhh3, Journey_SeXT and jkeaton 3 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted May 28, 2016 Report Share Posted May 28, 2016 CV joints click when they begin to fail. Check the boots for tears. If torn, the oil/grease will leak out, and the CV joint will fail. Journey_SeXT, 2late4u and Woah322 3 Quote Link to comment Share on other sites More sharing options...
