Lisa Persinger-Johnson Posted May 31, 2016 Report Share Posted May 31, 2016 My temperature on my dash doesn't change. When my son opened the passenger side door the emergency flashers flashed on my dash. What could it be? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 31, 2016 Report Share Posted May 31, 2016 Welcome to the forum. First thing to try is disconnecting the battery for a little bit to reset everything. This can be done from inside the engine compartment so you don't have to remove the fender liner to get to the actual battery. Try that and let us know. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted May 31, 2016 Report Share Posted May 31, 2016 Good information! ^^ jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 31, 2016 Report Share Posted May 31, 2016 (edited) Also, I think my flashers flash when the passenger door is opened, so your two issues may not be related. Probably a setting that can be changed somewhere to prevent the hazards from flashing. Edited May 31, 2016 by jkeaton dhh3 1 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted May 31, 2016 Report Share Posted May 31, 2016 If the passenger has a fob the doors will try to unlock and the flashers will flash . . . . . . jkeaton 1 Quote Link to comment Share on other sites More sharing options...
