Robert Cassner Posted June 3, 2016 Report Share Posted June 3, 2016 Have a 2012 Journey, when the speed hits around 50 I get a humming noise coming from the front. Any ideas? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 3, 2016 Report Share Posted June 3, 2016 Coming from the front where? Could be anything. Wind noise, wheel bearing, tire hum, etc. gotta narrow it down. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted June 3, 2016 Report Share Posted June 3, 2016 (edited) Sounds in a car can sound like they are coming from one area when actually they come fro another area. Do you have the cross rails on your roof? There are recommended spots to keep the noise to a minimum. Front: 3 detents back. Back: rear most detent. If you don't have the cross rails, forget this jibberish! The detents are marked by a line on the roof rails. Edited June 3, 2016 by dhh3 jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted June 3, 2016 Report Share Posted June 3, 2016 Sounds in a car can sound like they are coming from one area when actually they come fro another area. Do you have the cross rails on your roof? There are recommended spots to keep the noise to a minimum. Front: 3 detents back. Back: rear most detent. If you don't have the cross rails, forget this jibberish! The detents are marked by a line on the roof rails. this is good info , my cross rails made noise after I moved them to secure a load . ended taking them off ... dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
Robert Cassner Posted June 6, 2016 Author Report Share Posted June 6, 2016 Coming from the front where? Could be anything. Wind noise, wheel bearing, tire hum, etc. gotta narrow it down. Sounds like front left tire, going to rotate tires to see if it helps. the hum starts around 50 mph then gets quite around 70. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Robert Cassner Posted June 6, 2016 Author Report Share Posted June 6, 2016 Sounds in a car can sound like they are coming from one area when actually they come fro another area. Do you have the cross rails on your roof? There are recommended spots to keep the noise to a minimum. Front: 3 detents back. Back: rear most detent. If you don't have the cross rails, forget this jibberish! The detents are marked by a line on the roof rails. I have no cross rails dhh3 1 Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted June 6, 2016 Report Share Posted June 6, 2016 It could be a wheel bearing as I had a similar issue with a vibrating noise at certain speeds --> http://www.dodgejourneyforum.com/topic/2775-vibration-at-80kmh-2011-journey-sxt/?hl=%2Bwheel+%2Bbearing#entry17820 larryl, dhh3 and jkeaton 3 Quote Link to comment Share on other sites More sharing options...
