bdozer61 Posted June 11, 2016 Report Share Posted June 11, 2016 Came out of the store today and found a puddle under the bumper on the passenger front, definite coolant. I got home and popped the hood. The reservoir was low. I can see some evidence of liquid around the aluminum block and tubing connections on the passenger side of the radiator. Also a little orange \ rust colored crust on it also. Ran it in the driveway for 15-20 minutes. Was definitely up to temp, as the fans were running too. No leaks could be seen. I'm assuming there are probably o-rings in the block aside, but I can't find any reference to order them. Has anyone else had this issue or a diagram of the area? Thank goodness in advance Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 11, 2016 Report Share Posted June 11, 2016 Reservoir failures are quite common. It cracks along the seam. 2late4u and dhh3 2 Quote Link to comment Share on other sites More sharing options...
bdozer61 Posted June 12, 2016 Author Report Share Posted June 12, 2016 Thank you to the info. I know the tank on the inner fender as the reservoir. Are you referring to the tank on the side of the radiator as cracking? dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted June 12, 2016 Report Share Posted June 12, 2016 When you say aluminum block, do you mean the radiator (housing) or the engine? Quote Link to comment Share on other sites More sharing options...
bdozer61 Posted June 12, 2016 Author Report Share Posted June 12, 2016 I believe I was looking at the connection to the condenser, attached to the side of of the radiator. Just pulled the valance and can see drips all along the right side of the radiator. Think I need to bite the bullet and change the radiator dhh3 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 12, 2016 Report Share Posted June 12, 2016 I believe I was looking at the connection to the condenser, attached to the side of of the radiator. Just pulled the valance and can see drips all along the right side of the radiator. Think I need to bite the bullet and change the radiator just a thought my daughter's van was dripping just a little it was a new rad put in because a fan blade broke and went thur the rad. any way. i had a new cap left over from my work days from the plant so i put it on her new rad and it stopped the leak from the cap. just a thought.... dhh3 1 Quote Link to comment Share on other sites More sharing options...
bdozer61 Posted June 12, 2016 Author Report Share Posted June 12, 2016 Changed the radiator. Who designed the lower hose connection area?? The right side had staining up and down it. New rad is in. Thanks for the suggestions dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
