Heaavyt58 Posted June 14, 2016 Report Share Posted June 14, 2016 Any tips on replacing front struts on 2010 Journey? Well what I need to know is how to get to top bolts on struts Link to comment Share on other sites More sharing options...
Journey_SeXT Posted June 14, 2016 Report Share Posted June 14, 2016 REMOVAL NOTE Before proceeding, (Refer to Front Suspension/Front - Warning). Remove the engine appearance cover. COWL TOP SCREEN Remove the two push-pins (1) securing the cowl top screen at the ends. Remove the remaining push-pins (2). Remove the cowl top screen (3). Remove the wiper arms. (Refer to Electrical/8R - Wipers/Washers/ARM, Wiper - Removal) COWL SCREEN Remove the push-pins (1) securing the cowl screen to the wheelhouse brace and cowl. Rotate the screw (2) in the center of the cowl screen 90° clockwise to release the screen. Remove the cowl screen (3). Raise and support the vehicle. (Refer to Vehicle Quick Reference/Hoisting - Standard Procedure) TIRE AND WHEEL MOUNTING Remove the wheel mounting nuts (3), then the tire and wheel assembly (1). NOTE If both strut assemblies are to be removed, mark the strut assemblies right or left and keep the parts separated to avoid mix-up. Not all parts of the strut assembly are interchangeable side-to-side. BRAKE HOSE MOUNTING TO STRUT Remove the screw (1) securing the flex hose (2) routing bracket to the strut (6). STRUT MOUNTING TO KNUCKLE While holding the stabilizer bar link (1) stud stationary, remove the nut (4) securing the link to the strut (3). CAUTION The strut assembly-to-knuckle attaching bolts (5) are serrated and must not be turned during removal. Hold the bolts stationary in the knuckle while removing the nuts, then tap the bolts out using a pin punch. While holding the bolt heads stationary, remove the two nuts (2) from the bolts (5) attaching the strut (3) to the knuckle (6). Remove the two bolts (5) attaching the strut (3) to the knuckle (6) using a pin punch. Lower the vehicle just enough to open the hood without allowing the tires to touch the floor. STRUT UPPER MOUNTING NUTS Remove the three nuts (1) attaching the strut assembly (2) upper mount to the strut tower. Remove the strut assembly (2) from the vehicle. For disassembly, (Refer to Front Suspension/Front/STRUT, Suspension - Disassembly). Heaavyt58, dhh3, jkeaton and 1 other 4 Link to comment Share on other sites More sharing options...
jkeaton Posted June 14, 2016 Report Share Posted June 14, 2016 (edited) That's about the best tip you can get right there. Moved thread to the correct section. Edited June 14, 2016 by jkeaton dhh3 and Heaavyt58 2 Link to comment Share on other sites More sharing options...
Heaavyt58 Posted June 15, 2016 Author Report Share Posted June 15, 2016 Ty, I was right but I really didn't want to go through moving all that from above. Ty again much appreciated. Link to comment Share on other sites More sharing options...
