Camper Posted June 18, 2016 Report Share Posted June 18, 2016 Does any one received this error(please see attached) reported by body control module? I get this error, after replaced regular headlight light bulbs high and low beam with LED light bulb. To get that error, I went to my mechanic and used his professional ODB -II scanner. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 18, 2016 Report Share Posted June 18, 2016 Nope. I'm running LED's with no problems. Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 18, 2016 Report Share Posted June 18, 2016 try putting old ones back in to see if you get the error again if not put one led light at a time to see if you get the error again.... Quote Link to comment Share on other sites More sharing options...
Camper Posted June 22, 2016 Author Report Share Posted June 22, 2016 No matter what I try, I get those errors. Just replaced all headlights bulbs with LED, on my 2016 crossroad, hi beam and DRL working without any issue, as fog lights as well. However, low beam is different story. The lights, is turned on, so , when I switch gear to revers or drive position then right side low beam light turned off, when I put gear in the parking position and shout vehicle off light came back. I tried 4 different LED light bulb. However passenger light working without any issue. Quote Link to comment Share on other sites More sharing options...
Camper Posted June 22, 2016 Author Report Share Posted June 22, 2016 Old ,regular light bulbs, do not causing any error, only LED Quote Link to comment Share on other sites More sharing options...
bramfrank Posted June 23, 2016 Report Share Posted June 23, 2016 So, don't use LED bulbs.If you feel the need for more light either install HIR bulbs, which put out about 40% more light for the same power as stock, or add auxiliary lighting. JohnnyRevs, Powerz69 and jkeaton 3 Quote Link to comment Share on other sites More sharing options...
Powerz69 Posted September 9, 2016 Report Share Posted September 9, 2016 (edited) HIR all the way!!! Make sure your wires aren't backwards on the LED plug side before the LED driver. When I installed my HID ballasts I had the same issue, the lights would shut off when I put it into gear. I switched the wires at the plug on the relay harness and that solved the lights turning off when put into gear. My relay harness only uses the drivers factory light plug, that's why both of my lights went out. Edited September 9, 2016 by Powerz69 JohnnyRevs 1 Quote Link to comment Share on other sites More sharing options...
Camper Posted September 24, 2016 Author Report Share Posted September 24, 2016 My LED do not contain ballast, it direct plug and play. I tried to switching the wires at the plug still same issue.No idea what to do. Will keep original bulbs for now. Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted December 28, 2016 Report Share Posted December 28, 2016 Screw led bulbs haha. Go with HIR halogen or do a retrofit Quote Link to comment Share on other sites More sharing options...
Camper Posted January 17, 2017 Author Report Share Posted January 17, 2017 Issue was resolved today, by installing the harness with relay and one resistor. Now all LED light bulbs (same as jkeaton use) working as a charm, low beam, high beam, fog lights FlomotionJourney 1 Quote Link to comment Share on other sites More sharing options...
