tj021 Posted September 23, 2009 Report Share Posted September 23, 2009 I'm looking to put 20" rims on my Journey and everyone I talk to says the rim size that comes up (20x9) is to wide and will rub. Does anyone know what size rim(20x7.5,20x8,20x8.5) I can put on it and what size tire would work best(245/45-20)? And what offset I should use? Any advice would be helpful since it doesnt look like the rim shops in my area know much Quote Link to comment Share on other sites More sharing options...
bng804 Posted November 2, 2009 Report Share Posted November 2, 2009 I'm looking to put 20" rims on my Journey and everyone I talk to says the rim size that comes up (20x9) is to wide and will rub. Does anyone know what size rim(20x7.5,20x8,20x8.5) I can put on it and what size tire would work best(245/45-20)? And what offset I should use? Any advice would be helpful since it doesnt look like the rim shops in my area know much You can do 20s no prob. I've got some on order now. You have to be a little careful with the with the wheel width and don't go any wider than 8.5" to make sure they don't rub. Offset: +35mm Backspacing: 6.14" Bolt Pattern: 5-127 Rec. 20" Tire Size: 245/45-20 Quote Link to comment Share on other sites More sharing options...
oneframe Posted August 7, 2010 Report Share Posted August 7, 2010 Do you know the bolt size? I have a torque wrench, but don't have the proper bolt. Thanks. Quote Link to comment Share on other sites More sharing options...
ITtech Posted March 24, 2012 Report Share Posted March 24, 2012 I need the torque also, but I do know that I have to spend a buck or 25 on the Hanes manual, sold at autozone. This manual is a god send to the average backyard mechanic like most of us. It will have all the torque specs and much more info that is needed by folks like us. I have had one for every single vehicle I have owned and now have to buy one for this one, I am just short on cash till next payday lol. BTW, the rims 20x8.5 with +35offset and 5x127 bolt pattern is a good fit, that is what I will be getting next year this time or sooner. Check out wheelsnext.com for a descent selection of wheels that will fit the journey, just type in your year and model and the ones selected will fit, but I double check the offset and bolt pattern always just to be safe. Quote Link to comment Share on other sites More sharing options...
Aldx Posted March 28, 2012 Report Share Posted March 28, 2012 I just recently tried to purchase from wheelsnext.com, it was tough and a pain in the butt. I live in europe and would call then and call them to make sure they had what I wanted in stock, because I didn't want to wait 6-8 weeks just for them to get in the rims I wanted. I found my Helo 868's on tire rack, you can check them out, my journey is an '09 Inferno red. Take your time on your wheel purchase. Quote Link to comment Share on other sites More sharing options...
Gman Posted September 14, 2012 Report Share Posted September 14, 2012 anyone done 22"? Quote Link to comment Share on other sites More sharing options...
