Usefu1_1diot Posted July 8, 2016 Report Share Posted July 8, 2016 Got some LED lights off Amazon (Cutequeen brand) and put them all in yesterday. Everything seemed to work great at first. They came on when I pressed the button, opened the doors and turned them on using the dial in the dash. Today however, they won't come on using the dial of when I open the doors, they only come on when I press the button on the light itself. Am I doing something wrong or do I need different lights (possibly that require less voltage to activate)? My only guess is that using the dial and opening the doors may push less voltage to the lights than using the button. But I have no idea Quote Link to comment Share on other sites More sharing options...
jkeaton Posted July 8, 2016 Report Share Posted July 8, 2016 I replaced all mine with regular LED's (read: non-canbus) and they work just fine. Not sure what your problem could be. Take them out and reseat maybe? Quote Link to comment Share on other sites More sharing options...
bramfrank Posted July 8, 2016 Report Share Posted July 8, 2016 Reseating won't change anything if they work when you manually turn them on. Quote Link to comment Share on other sites More sharing options...
Usefu1_1diot Posted July 8, 2016 Author Report Share Posted July 8, 2016 Well it seems there is no rhyme or reason to it now. They turn on find by pressing the button, and now it seems they come on when the doors opens "sometimes"! The one in the cargo area doesn't seem to come on at all though. I'm confused. They were super easy to put in, so I'd get a different kind if I knew it would fix the issue. What voltage are suppose to use? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted July 9, 2016 Report Share Posted July 9, 2016 12 volts Quote Link to comment Share on other sites More sharing options...
Usefu1_1diot Posted July 10, 2016 Author Report Share Posted July 10, 2016 Well that's what the LED lights are, so I have no idea. Time to switch back the factory lights so I can see when I open my doors for now. Damn... Quote Link to comment Share on other sites More sharing options...
