how to fix trouble code p076a
journey went into limp mode yesterday. had it put on computer and got p076a shift solenoid "h" and code p0452 nvld pressure switch circuit low input. the latter i had gotten before and is likely not the problem. the only thing i've been able to find on the subject is a thread on code p076a where the guy ended up changing a fuel pump. seems to go against common sense that a solenoid located in the transmission is affected by the fuel pump. alright, i really need help. i can't afford a mechanic.
  • 4 months later...
  • 4 years later...
