Auto window down with remote
It was documented as a feature in the 2011 owner's manual (called remote open window), but has since disappeared.  That, of course doesn't mean anything in and of itself because they stopped documenting the seat belt minder disable procedure too and they include also descriptions of all sorts of neat things we don't get like;
- power folding mirrors,
- headlight washers,
- rain sense wipers,
- blind spot alert,
- auto-dim high beams,
- steering directed lights,
- seat position memory.
- front collision warning
The remote open window feature was, I believe a function of the remote starter package, which is included in your R/T's equipment, so if it still existed, your vehicle would probably have had it.
Here are the instructions, as they appeared in the 2011 owner's manual:
Remote Open Window Feature
This feature allows you to remotely lower both front door
windows at the same time. To use this feature, press and
release the UNLOCK button on the RKE transmitter and
then immediately press and hold the UNLOCK button
until the windows lower to the level desired or until they
lower completely.
