mfenske Posted August 5, 2016 Report Share Posted August 5, 2016 Wife got a 16 SXT as a work vehicle yesterday. Has the 4.3" Touchscreen with BT and no XM. How do I tell if it's a CANBUS unit? dhh3 1 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted August 5, 2016 Report Share Posted August 5, 2016 They're all CANBUS. Why does it matter? dhh3 1 Quote Link to comment Share on other sites More sharing options...
mfenske Posted August 5, 2016 Author Report Share Posted August 5, 2016 From the limited information I have there's a different interface required to tap in to the factory audio system if it is. dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 5, 2016 Report Share Posted August 5, 2016 Just use Bluetooth. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted August 6, 2016 Report Share Posted August 6, 2016 (edited) Not sure what you are trying to do, but the whole vehicle runs on the CanBus system; the only difference being whether it is the High Speed System, or the Low Speed System. My Nitro was High Speed. I have no idea what the DJ uses. This is why item's Sales Codes added have to be added to the build list so that they can be activated. Nothing is simple anymore. Edited August 6, 2016 by dhh3 Quote Link to comment Share on other sites More sharing options...
mfenske Posted August 10, 2016 Author Report Share Posted August 10, 2016 What I'm wanting to do is to tap in to the exisiting stereo to provide an input to an external processor that I'll then feed in to an aftermarket amplifier. I'd prefer not to buy the PAC-CHY5 if I don't have to but if that's what works so be it. Quote Link to comment Share on other sites More sharing options...
dhh3 Posted August 11, 2016 Report Share Posted August 11, 2016 You will need an aftermarket harness that plugs into the back of the radio. Cut this harness, and do your wiring; then plug the other end of the harness into the one that was plugged into the back of the radio. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
mfenske Posted August 11, 2016 Author Report Share Posted August 11, 2016 The harnesses are pretty easy-I've used forward and reverse harnesses to tap in to signal before. I'm just wanting to know if there's anything else i need to be aware of so that it actually outputs signal if it's not under load or throws a code. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted August 11, 2016 Report Share Posted August 11, 2016 Mine has never thrown a code with the addition of an amp and sub. mfenske 1 Quote Link to comment Share on other sites More sharing options...
